NethServer project milestone 8.10
Another quarter, another checkpoint on the NethServer 8 journey: we’re happy to announce milestone 8.10! This cycle we focused on:
  • delivering the long-awaited Mail improvements
  • turning finished UX designs into new cluster-admin pages
  • giving more visibility into CrowdSec protection
  • laying the groundwork for single sign-on
  • core and application updates
:star2: Enhancements
Here are the highlights introduced since milestone 8.9.
The full list is available in the release notes for milestone 8.10.
Turn off automatic updates from the Software Center
With an active subscription, applications are updated automatically overnight. You can now switch this off from the Software Center, for the whole cluster or for single applications, without command-line procedures. Applications left out are marked with an Updates disabled tag and can still be updated by hand.
New TLS certificates settings
The TLS certificates page has a new ACME settings tab. Besides the certificate authority address, it lets you choose how each node proves domain ownership to Let’s Encrypt: through port 443 (the default TLS-ALPN-01 challenge) or through the legacy port 80 (HTTP-01 challenge).
Frontend proxies
If your NethServer sits behind a reverse proxy, a load balancer, or a CDN, the new Frontend proxies tab of the HTTP routes page tells it which proxies to trust, so it can see the real address of visitors. Previously this was possible only with API calls.
New Grafana dashboards
Two new Grafana dashboards are available with the Metrics application:
  • Containers shows the CPU, memory, and disk space used by each application, so you can quickly find out what is keeping a node busy or filling its disk. Disk usage is refreshed once a day.
  • CrowdSec Bans shows the history of blocked attackers over the whole log retention period (one year by default): a world map, bans over time, top countries, providers, attack types, and the IP addresses that keep coming back.
Smarter System logs search
The System logs page can now search with regular expressions, and errors and warnings stand out with colors, so problems are easier to spot at a glance. Thanks to @pagaille for the contribution :heart:
CrowdSec: see what’s going on
New CrowdSec pages show what was previously visible only from the command line:
  • Detections: the history of suspicious activities, with source and details
  • Collections: turn detection for each service on or off
  • Blocklists: local and community blocklists, and the allowlist, in one place
CrowdSec can also protect NethVoice against password-guessing attacks on phones and web applications, and its ban history is now available in Grafana, as described above.
Clusters with an active subscription will also get a new Threat Shield page. Stay tuned: we’ll share more about it in a dedicated announcement soon!
Phone extension for users
Users have a new Phone extension field, which can be set from cluster-admin and from the User Management portal.
Mail: alias addresses from the user domain
A new mail domain option turns the mail attribute of each user into an extra email address for that user, which also works as a sender address.
:key: New subscription portal
The new portal for Enterprise subscription customers is online at https://beta.my.nethesis.it. It provides monitoring, alerts, and inventory for clusters running Core 3.23 or later.
  • New clusters: first update the core to the latest version, then get the subscription token from the new portal and paste it in the Subscription page.
  • Already registered clusters: no action is needed. They connect to the new portal automatically once updated to Core 3.23 or later.
:wrench: Other changes
Core
  • Pages load faster on clusters without internet access.
  • Tables remember your Items per page choice.
  • The installer no longer accepts Debian 12, as announced in milestone 8.8.
Mail
  • Forwarding to external addresses finally works reliably: forwarded messages are no longer rejected as forged by the destination server.
  • The antivirus Third-party signatures rating setting is now applied.
  • Logins with Active Directory are more reliable and fill the logs with less noise.
Webmail and WebTop
  • Roundcube creates the Drafts and Sent folders at the first login.
  • WebTop is updated to 5.35.7, and Thunderbird now configures mail accounts with fully encrypted connections from the start.
Piler mail archive
  • Piler now runs on our own container image, so we can ship security updates faster and test each new Piler release before it reaches you.
  • The container runs with fewer privileges, and Piler logs are now visible in the System logs page.
  • Importing mail from an IMAP account works again.
  • The service is more robust: it no longer keeps running half broken, and mail still queued is archived before it stops.
Other applications
  • Dependency-Track moves to version 5. Existing installations need a manual upgrade.
  • Loki and Nextcloud updates.
:beetle: Bug fixes
20+ bugs have been addressed across core components and applications to improve stability and reliability. Here is a brief list:
The full list is available on our GitHub issue tracker.
:compass: Roadmap
The single sign-on (SSO) goal of the previous milestone produced its first result: the developer documentation now describes how NS8 identity provider applications plug into the system. Consider it an open working draft. Its reference implementation, the new ns8-idp application, is already under development (alpha).
Besides open issues, with priority to the backup ones, the next goals are:
  • Single sign-on for Nextcloud, Roundcube, Mail, NethVoice, and WebTop, with the new ns8-idp application
  • Moving application data to an additional volume after the application is installed, with the volumectl command
  • Dovecot 2.4 for the Mail application, including the migration of existing mail servers
We’ll also start the UI design of:
  • Operating system updates and scheduled node reboots, important for kernel security fixes and Rocky Linux minor updates
  • Let’s Encrypt DNS challenge, which is much slower than the current methods and may need a different workflow
  • Application-specific alerts, and how to display them
Follow the roadmap on our project page.
:handshake: Join the NS8 community
Your participation helps shape the direction of the project:
  • Join the forum discussions using the tag ns8
  • Share feedback, report bugs, and propose improvements
  • Contribute translations on Weblate
Thanks for being part of the journey — together we’re building the future of NethServer.
The NethServer Team
So cool, I can’t wait for it. It feels like an old bloke after three pints in a pub, busting outside a locked toilet door …
you know what, I am happy :smiley:
this is great progress.
I am curious, however, why Keycloack was chosen as the base?
Thanks for the question! We chose Keycloak because it’s a mature project and feature-complete for our purposes, including the Microsoft Entra ID and Google Workspace federation we have planned. It has been developed since 2013, it’s Apache 2.0 licensed, and it has been a CNCF incubating project since 2023.
That said, we’re keeping the door open to other implementations. What the documentation describes is a generic architecture for plugging identity provider applications into NS8, and many different products could implement it. The Keycloak-based implementation is just an alpha, and we may switch to another product during the next milestone.
this is an Important Statement, and its great, that the implementation will be pluggable and not just a fixed Implementation.
this Opens a lot of Opportunities, for integrations as well.
Other candidates we haven’t tested yet for ns8-idp are Authentik and Zitadel. From their documentation, Zitadel looks lighter on memory but offers less theming flexibility, while Authentik has easy UI-based branding but a footprint similar to Keycloak’s.
What is the current Status of NethServer/ns8-idp: Single sign-on and identity federation for NethServer 8 applications, based on Keycloak
what i mean is, if a new user, isntalls NS8-idp can they sue the keycloack in production, for authenticating other Non NS8 Apps, pending NS8 Apps coming along to get it done.
Regarding Zitadel Offering Less theming, Look into zitadel/example-auth-vue: Official Zitadel auth example for Vue.
zitadel offers custom login, authentication and management UI, through their theming and customizations UI. zitadel Login UI (Login V2)
tell me what kind of such customizations you are looking for and i can share my findings around the same. this is why many SaaS providers, who offer multi products authentication, make use of it. its one of their biggest markets.
/btw … I know roadmap is road map, but would you mind to consider FIDO sticks / webauth as a second TFA next to OTC - A FIDO stick is cheaper and easier deposited in a safe vault than a complete mobile phone with the respective app … yes, a sheet of paper with the backup codes will do the same, but it not that cool :slight_smile:
@davidep Ping
Hi Martin, I missed your question, sorry!
As said before, ns8-idp is just an alpha, maybe less than alpha. The milestone goal was evaluating the design and impact on NS8 architecture. I just implemented a prototype for that.
