Nethserver on Raspberry Pi
I remain available if I can be useful.
Thank you a lot.
Federico
Which repo is nethserver-cockpit in?
I am wanting to install it on a NethServer installation on a Raspberry Pi.
try this?
Thanks @mark_nl, it was only after I posted this did I realise I was using the wrong image.
Thanks a million for the link
Happy to hear your feed back,
(btw cockpit is pre-installed…)
I will buy a Banana Pi BPi-R4 this or next month, and I would like more secure-focused than pure OpenWrt. I can’t use OPNsense or PFsense because they are AMD64 only, so Nethsecurity seems a good compromise.
The NethSecurity build system already supports different targets, see Build system | NethSecurity
Use this commit as an example on adding a new board.
Is it also support ARM64 or just AMD64?
It’d support all targets supported by openwrt, arm64 for sure.
