hi
nethserver information:
System version:NethServer release 6.6 (Final)
Kernel release:2.6.32-504.el6.x86_64
I config nethserver6.6 as a PDC,then i enable web proxy and authentication.
so i think this time proxy should use NTLM authentication.i also check the squid config file,i can see that squid use the NTLM authentication.
i begin to use the proxy on IE11 and firefox37 ,but authenticate unsuccessfully
Below is the access log file of squid:
i use the admin account and test who i add a new account.
1433911508.401 380 10.204.190.42 TCP_DENIED/407 3711 CONNECT 10.204.191.128:443 - HIER_NONE/- text/html
1433911516.884 357 10.204.190.42 TCP_DENIED/407 3800 CONNECT 10.204.191.128:443 test HIER_NONE/- text/html
1433911549.794 3 10.204.190.42 TCP_DENIED/407 3693 CONNECT 10.204.191.127:980 - HIER_NONE/- text/html
1433912290.503 0 10.204.190.42 TCP_DENIED/407 3806 CONNECT 10.204.191.129:443 - HIER_NONE/- text/html
1433912297.876 24 10.204.190.42 TCP_DENIED/407 3895 CONNECT 10.204.191.129:443 test HIER_NONE/- text/html
1433912309.504 1 10.204.190.42 TCP_DENIED/407 3895 CONNECT 10.204.191.129:443 test HIER_NONE/- text/html
1433912339.289 1 10.204.190.42 TCP_DENIED/407 3895 CONNECT 10.204.191.129:443 test HIER_NONE/- text/html
1433912736.533 8575 10.204.190.42 TCP_MISS/200 9183 CONNECT 10.204.191.128:443 admin HIER_DIRECT/10.204.191.128 -
1433912736.533 8576 10.204.190.42 TCP_MISS/200 14543 CONNECT 10.204.191.128:443 admin HIER_DIRECT/10.204.191.128 -
1433912736.533 8660 10.204.190.42 TCP_MISS/200 385166 CONNECT 10.204.191.128:443 admin HIER_DIRECT/10.204.191.128 -
1433912736.533 8746 10.204.190.42 TCP_MISS/200 720665 CONNECT 10.204.191.128:443 admin HIER_DIRECT/10.204.191.128 -
1433912736.534 8657 10.204.190.42 TCP_MISS/200 29923 CONNECT 10.204.191.128:443 admin HIER_DIRECT/10.204.191.128 -
1433912736.534 8655 10.204.190.42 TCP_MISS/200 12399 CONNECT 10.204.191.128:443 admin HIER_DIRECT/10.204.191.128 -
1433912736.534 8656 10.204.190.42 TCP_MISS/200 37492 CONNECT 10.204.191.128:443 admin HIER_DIRECT/10.204.191.128 -
1433912736.534 8660 10.204.190.42 TCP_MISS/200 94236 CONNECT 10.204.191.128:443 admin HIER_DIRECT/10.204.191.128 -
1433912736.534 8820 10.204.190.42 TCP_MISS/200 148192 CONNECT 10.204.191.128:443 admin HIER_DIRECT/10.204.191.128 -
so please help to check the issue
