NethServer Imap problem
[root@nethserver ~]# yum history pkg-info dovecot
Transaction ID : 133
Begin time : Tue Dec 4 08:15:25 2018
Package : dovecot-1:2.2.10-8.el7.x86_64
State : Updated
Build host : c1bm.rdu2.centos.org
Build time : Thu Aug 3 08:52:54 2017
Packager : CentOS BuildSystem http://bugs.centos.org
Vendor : CentOS
License : MIT and LGPLv2
URL : http://www.dovecot.org/
Source RPM : dovecot-2.2.10-8.el7.src.rpm
Commit Time : Tue Mar 21 13:00:00 2017
Committer : Michal Hlavinka mhlavink@redhat.com
Reason : dep
From repo : base
Installed by : System
Package : dovecot-1:2.2.36-3.el7.x86_64
State : Update
Build host : x86-01.bsys.centos.org
Build time : Wed Oct 31 01:24:57 2018
Vendor : CentOS
Source RPM : dovecot-2.2.36-3.el7.src.rpm
Commit Time : Wed Sep 19 14:00:00 2018
Reason : dep
From repo : base
Changed by : root
Transaction ID : 3
Begin time : Wed Nov 15 20:53:59 2017
State : Dep-Install
Vendor : CentOS
Reason : dep
From repo : base
history pkg-info
[root@nethserver ~]# grep NsReleaseLock /var/log/messages
Dec 4 08:21:21 nethserver /sbin/e-smith/db[81454]: /var/lib/nethserver/db/configuration: OLD sysconfig=configuration|Copyright||DefaultLanguage|en_US.utf8|NsReleaseLock|disabled|ProductName|NethServer|Release|final|Version|7.5.1804|ZeroConf|enabled
Dec 4 08:21:21 nethserver /sbin/e-smith/db[81454]: /var/lib/nethserver/db/configuration: NEW sysconfig=configuration|Copyright||DefaultLanguage|en_US.utf8|NsReleaseLock|enabled|ProductName|NethServer|Release|final|Version|7.5.1804|ZeroConf|enabled
Dec 4 09:43:49 nethserver /sbin/e-smith/db[15021]: /var/lib/nethserver/db/configuration: OLD sysconfig=configuration|Copyright||DefaultLanguage|en_US.utf8|NsReleaseLock|enabled|ProductName|NethServer|Release|final|Version|7.5.1804|ZeroConf|enabled
Dec 4 09:43:49 nethserver /sbin/e-smith/db[15021]: /var/lib/nethserver/db/configuration: NEW sysconfig=configuration|Copyright||DefaultLanguage|en_US.utf8|NsReleaseLock|disabled|ProductName|NethServer|Release|final|Version|7.5.1804|ZeroConf|enabled
Dec 4 09:50:21 nethserver /sbin/e-smith/db[16503]: /var/lib/nethserver/db/configuration: OLD sysconfig=configuration|Copyright||DefaultLanguage|en_US.utf8|NsReleaseLock|disabled|ProductName|NethServer|Release|final|Version|7.5.1804|ZeroConf|enabled
Dec 4 09:50:21 nethserver /sbin/e-smith/db[16503]: /var/lib/nethserver/db/configuration: NEW sysconfig=configuration|Copyright||DefaultLanguage|en_US.utf8|NsReleaseLock|enabled|ProductName|NethServer|Release|final|Version|7.5.1804|ZeroConf|enabled
Run the following commands to disable the antispam plugin:
mkdir -p /etc/e-smith/templates-custom/etc/dovecot/dovecot.conf/
touch /etc/e-smith/templates-custom/etc/dovecot/dovecot.conf/50spam_training
expand-template /etc/dovecot/dovecot.conf
systemctl stop dovecot.service
systemctl start dovecot.service
To undo:
rm /etc/e-smith/templates-custom/etc/dovecot/dovecot.conf/50spam_training
Transaction ID : 56
Begin time     : Tue Dec  4 03:53:52 2018
State          : Updated
Packager       : CentOS BuildSystem <http://bugs.centos.org>
Vendor         : CentOS
Committer      : Michal Hlavinka <mhlavink@redhat.com>
Reason         : dep
From repo      : base
Installed by   : System <unset>
Transaction ID : 56
State          : Update
Vendor         : CentOS
Reason         : dep
From repo      : base
Changed by     : root <root>
Transaction ID : 3
Begin time     : Fri Feb  2 10:53:23 2018
State          : Dep-Install
Vendor         : CentOS
Reason         : dep
From repo      : base
history pkg-info
Thanks so much now all works fine
Now I have another problem.
I have all the emails in the queue and NethServer can not send them
This problem was born after I deactivated the antispam plugin
As workaround it is now possible to upgrade to 7.6.1810 beta, as explained here
After that, remove the template-custom as explained above
You may also have to deactivate the anti spam filter rules (I did so some time ago). You can do this in the web interface under Configuration / Email / Filter.
Ok, I waited a few minutes and now they all left.
Thank you and sorry
