@Andy_Wismer as an engineer, you should very well know that trying to figure something out, if it has merits is not a waste of time, it actually helps alot of things.
ALot of things we have in this world exist because soeone once asked a question, and the prodcut, solution or resolution becomes the answer to that question.
Apart from NEthserver 8, there is actually a reasonable merit to my query as well as proposal. and i think @giacomo understands the need and the question at hand.
With every question i asked, and every reason i ask, its designed as both a user as well as from a developer point of view, After all, I am a Systems solutions architect for over 10 years now. and still have a long way to go, and alot more to learn from people that came before me.
No One and absolutely no one has mentioned anything about having 2 separate AD, it was with regards to 2 seprate NEthserver instances that are cluster admin.
the fact that a NEthserver instance is a cluster Admin, does not necessarily mean it must be or have an AD running, there are other uses to this. and with the discussion on vpn cluster interconenct with nethsecurity, its expanding on to this.
I know many Enterpise coporate and even SME who would use such features. especially those with multiple branches.
My Excuses get things Done, In relation to My NS7 migration, atleast i am doing something About it here: compgeniuses/ns8-goauthentik at certgen (github.com)
As indicated on the plan, I am working on an SSO module for Nethserver 8, its almost complete, Once i can validate it, ill deploy a new NEthserver 8 instance, INstall the SSO onto it, Migrate my AD to Nethserver 8, HAve the SSO module linked, Implement the NEw SSO into all systems i am using with SSO.
ATLEAST I AM DOING SOMETHING ABOUT IT ANDY
-MPOM-
