This is a simple Mattermost installation:
- users are not integrated with system users due to a Mattermost Team edition limitation
- it’s accessible in HTTPS only
- you need a dedicated hostname for the virtualhost like
mattermost.nethserver.org
- no web interface for configuration
Just execute:
yum --enablerepo=nethforge-testing install nethserver-mattermost
config setprop mattermost VirtualHost mattermost.yourdomain.com status enabled
signal-event nethserver-mattermost-update
Then, access `https://mattermost.yourdomain.com`` and perform the first configuration.
More info here:
- https://github.com/gsanchietti/nethserver-postgresql94
- https://github.com/gsanchietti/nethserver-mattermost
Drop your comments below
