does everyone on riot have the same permisions.
looks like there is no administration panel, or administrative interface that has added functionality.
every user typer, either ldap user, normal user, etc, have the same user abilities.
Hi @oneitonitram
Matrix - synapse obviously still needs a lot of development. If you search for matrix synapse admin panel you will find a lot of hits.
On github someone has started to develop an admin interface: https://github.com/aminhusni/Trinity_Matrix_Management_GUI
Maybe this is a start? Otherwise I understand you are stuck at commandline db management. Although the recommended way to manage users and rooms is through the API.
https://github.com/matrix-org/synapse/issues/1707#issuecomment-293381066
Here some documentation on the API: https://github.com/matrix-org/synapse/tree/master/docs/admin_api
then, when we make it a module, we could add some function into neth
Work on the gui looks like abandonned now. I think we should rely on API use for now⦠Bit if we can have a clear list with commando, that shouldnāt be a showstopper.
commando?!!!
@mrmarkuz can we begin the bridge integrations process today.
i can deploy a test server and help test.
we can begin with:
looks like majority rely on python and virtuel env
Iād like to finish another project today but I can help with matrix bridge installation.
ok. then we begin with the discord bridge.
How to install the discord bridge. and have it work with matrix.riot on nethserver
Seems not trivial. Iāll be back when I got something working but it may take some timeā¦
I hope that other bridge installs are similarā¦
all of these, if not most, as similar installations.
the ones I left out, are way more complicated.
especially the one for WhatsApp.
well, even thoough we at NethCommunity love complex
I added a Bridges chapter with discord to the howto but I get an error when starting the docker containerā¦
On a sidenote: the matrix weekly blog is quite interesting and informative
https://matrix.org/blog/2020/03/20/this-week-in-matrix-2020-03-20
i thought there are 2 methods.
installing without docker, and install with docker.
from the content atop, seems you utilized the one without docker.
so why are you running docker?
I thought itās needed, I didnāt read about 2 methods.
oh, sorry, i had confused with another bridge instructions.
yes its the same process
did you manage to resolve the error you are getting?
as if we could figure it out, we can replicate with other similar modules and get them to work.
Jambo @oneitonitram!
keep up the good work!
As soon as I have something working Iāll post itā¦
Hi, I did install synapse and Riot and itās working great thanks to your tuto.
Iām actually struggling with videocalls and TURN⦠Did someone manage to make it work ?
Thanks
welcome to our community.
Thanks for testing synapse/riot, feel free to provide your ideas about implementation and preconfiguration.
Check out this post about configuring coturn:
