i finally installed a TURN server, i am afraid to touch the homesever.yaml file to to integrate it into matrix/synapse.
Especially the uri, not sure how to set it.
You may backup your homeserver.yaml and just try the suggested example:
turn_uris: [ "turn:turn.matrix.org:3478?transport=udp", "turn:turn.matrix.org:3478?transport=tcp" ]
what about the port.
the ones listed on that example are not the ones we activated on the other link
these are the ones setup
below are the ones listed.
3478
Use the ones that are active.
You can check the open ports with
netstat -tlpnu.
turnserver listed on
3478 tcp
3478 udp
done as instructed, no erros, but i dont notice any differences.
i am not sure if its because all calls happen throught jitsi.matrix.im or what.
on the telegram bridge, i get error : -bash: ./bin/activate: No such file or directory
Thanks, I forgot the scl enableā¦Iām going to fix it in the howtoā¦
scl enable rh-python36 bash
virtualenv -p /usr/bin/python3 .
source ./bin/activate
thank you for that.
now getting
The path /usr/bin/python3 (from --python=/usr/bin/python3) does not exist
Python36 should already be installed. Do you install on another machine than the matrix-synapse host?
yum -y install rh-python36
it is the same machine that has matrix synapse
as shown here
What happens if you install it?
Package rh-python36-2.0-1.el7.x86_64 already installed and latest version
Nothing to do
inside user/bin
Please try
virtualenv .
The path is for python3 but we use rh-python36.
Using base prefix '/opt/rh/rh-python36/root/usr'
New python executable in /opt/mautrix-telegram/bin/python3
Also creating executable in /opt/mautrix-telegram/bin/python
Installing setuptools, pip, wheel...done.
Hello,
Itās cool to see Matrix/Synapse coming on NS!! Many thanks for your great work
Iām testing this howto on a VM, and I have problems to reach the Matrix server with Riot. Itās frustrating, Iād like to test the bridges!
I installed Matrix on a VM on my workstation. The VM is a Nethserver. I call it: āNS2ā (FQDN: matrix.mydomain.com), connected on the LAN.
My workstation is on the LAN, behind a NS server āNS1ā (FQDN: ns1.mydomain.com)
NS1 is connected to the Internet and to the LAN, with 2 NICs. WAN is 192.168.1.x and LAN is 192.168.2.x
So, I have created a reverse proxy on NS1:
matrix.mydomain.com --> https://192.168.2.123
I have a valid LE certificate on NS1 for matrix.mydomain.com and Iāve set the: Accept invalid SSL certificate from target.
I donāt have any LE certificate on NS2.
Riot works, I can reach it from my workstation, and from the Internet.
But Riot can reach Matrix only if Iām from my workstation, and if my config.json is with the IP of NS2:
"default_server_config": {
"m.homeserver": {
"base_url": "https://192.168.2.123",
And Matrix canāt reach #synapse:matrix.org
If config.json is with the FQDN, Riot say it canāt reach the Matrix server.
And if Iām from the Internet, whether the config.json is based on IP or FQDN, Riot say it canāt reach Matrix.
What do you think about this?
Bad certificate for the NS2? Reverse proxy? Something else⦠?
Thanks for your help.
Fist things first, i belive the biggest problem or blunder you made, is that you installed matrix on the same subdomain as your server hostname, these should be differet.
1:e svr1.domain.com while matrix goes to matrix.domain.com but dont use the same hostname as the installation for other software.
I guess itās the reverse proxy. You may need to copy the proxypass nocanon option and the AllowEncodedSlashes NoDecode from the matrix httpd configuration to a manual reverse proxy on NS1.
To check if itās the reverse proxy you could do a port forwarding instead of the reverse proxy, get letsencrypt on NS2 and see if that works.
Finally I done this install on a vps.
Matrix, Riot, federation and LDAP works well.
I have a problem with the Telegram bridge, at this command:
[root@matrix mautrix-telegram]# python -m mautrix_telegram -g
/usr/bin/python: No module named mautrix_telegram
What did I miss?
And, you talk about TURN, is there a howto?
@oneitonitram
The difference I found for the admin is he can create communitys, not users.
