IPS Bypass IP rspamd_proxy
v7
ips
(L) #1
NethServer Version: 7.5
Module: IPS
Hello
I try to Enable IPS but there are some errors on rspamd_proxy as shown below
Please help and how to set By pass IP rspamd_proxy
11/26/2018, 10:56:53 AM rspamd_proxy 7341 proxy f8b98e got IO timeout with server fuzzy1.rspamd.com(88.99.142.95:11335), after 1 retransmits
11/26/2018, 10:53:56 AM rspamd_proxy 7341 proxy 65185f got IO timeout with server fuzzy2.rspamd.com(212.24.145.107:11335), after 1 retransmits
11/26/2018, 10:51:59 AM rspamd_proxy 7341 proxy 2a9883 got IO timeout with server fuzzy1.rspamd.com(88.99.142.95:11335), after 1 retransmits
11/26/2018, 10:48:58 AM rspamd_proxy 7341 proxy 6c9eec got IO timeout with server fuzzy1.rspamd.com(88.99.142.95:11335), after 1 retransmits
11/26/2018, 10:43:52 AM rspamd_proxy 7341 proxy 10de56 got IO timeout with server fuzzy1.rspamd.com(88.99.142.95:11335), after 1 retransmits
Thank you
(Markus Neuberger) #2
Does it occur regularly?
Are you sure it’s related to IPS?
You may check IPS logs with Evebox.
Found another thread about that:
(L) #3
Yes, sure after activate the IPS then the messages shown above
Can I allow these IPs in evebox ?
Thank you
(Markus Neuberger) #4
You’re welcome, I am afraid you have to find which ips rule category is blocking and set it to alert in IPS settings.
To find the blocking rule category have a look at /var/log/suricata/fast.log or evebox.
http://docs.nethserver.org/en/v7/suricata.html#rule-categories
(L) #5
Hello @mrmarkuz
Thank you so much
It seems show on category “Network Trojan”
(Markus Neuberger) #6
You’re welcome. Did you set the trojan rule category to alert or did you disable the IPS to make it work? Which rspamd version do you use?
I got the same rspamd_proxy error messages but my IPS is set to alert. I am going to investigate further, if IPS impacts rspamd we at least have to write it to the docs…
I can confirm the error occurs with activated IPS.
(L) #7
Thank you again
(L) #8
Hello
A few days ago I have been updated the Nethserver but still errors on rspamd_proxy after activate IPS
