IP Alias for use with VM
NethServer Version: v7
Module: webvirtmgr
I have two external IPv4s, one is assigned to a bridge and is my first used IP. This is working okay.
The other IP is assigned as an alias on the same bridge and I’ d like to use this external IP in a VM. How can I achieve that? I can not see this in the official Documentation, also, could I help you with updating the Documentation if I see some wrong translations or if I see that something is missing?
Tony
Of course, you’re very welcome.
You can edit documentation and create a pull request on github (see “Edit on GitHub” link at the top-right corner of the online documentation).
There is also a wiki in need of some love from the community, like this webvirtmgr howto.
And translations on transifex.
Check also:
