Hi all,
I tried to install Rocky-9.2 and 9.1, using the minimum ISO or the DVD ISO on Ubuntu 22.04 LTS VirtualBox-6 and 7, on Proxmox7.4.3 and all of them give me **kernel panic**.
I even redownload the ISO and checksum is OK.
Installation OK on Win-8.1 with VirtualBox-7.0.6 and I can install NS-8 beta-1.
Installation of Rocky-8.x is OK.
What I do wrong ?
Michel-André
mrmarkuz
(Markus Neuberger)
May 24, 2023, 5:16pm
2
There’s a known bug, did you set the CPU in Proxmox to something other than kvm64 as explained here ? See also [SOLVED] - Kernel panic installing rocky or almalinux | Proxmox Support Forum
As regards Proxmox sometimes you need to start the VM a second time, especially when you resize the disk.
As regards Virtualbox, I converted the image to vdi and it worked, see NS8B1 first test - #4 by mrmarkuz
Hi @mrmarkuz
Setting the CPU Type to host and now it’s working.
You’re the best !
Michel-André
mrmarkuz
(Markus Neuberger)
Split this topic
May 25, 2023, 8:25pm
4
mrmarkuz
(Markus Neuberger)
Split this topic
May 25, 2023, 8:26pm
5
