I tried installing from USB, but it requires kickstart settings. Is there a guide somewhere for installing from USB stick? A lot of smaller computers used as office routers or firewalls nowadays don’t have CD/DVD drives, so installation from USB should be an option supported IMHO.
You must install a standard CentOS from the USB then convert it to a NethServer (see: First(s) installs, few observations and help still needed)
Maybe USB install for NethServer will be available with CentOS 7 but we need to do some analysis.
ok, i will do that.
just an idea, maybe using kickstart like this would be a solution:
I did it for elastix which is CentOS based and it worked nice.
