Immich - photo and video management
Updated to Release 1.0.3 · mrmarkuz/ns8-immich · GitHub
The machine learning model-cache was included in backup but it’s not needed so I removed it to save backup space.
Tested backup and restore, no issues.
Wow guys, tested and really liked it!
Thank you!!
Nice! I also really like the mobile app. It allows me to auto backup all mobile camera pics, video’s and whatsapp images/videos.
FYI
Just visited my immich and was served with this
and it seems important:
We don’t use relative paths so we’re not affected by the “breaking” change.
Here is the v1.136.0 testing, the update worked for me.
Install:
add-module ghcr.io/mrmarkuz/immich:1.0.4-dev.1
Update:
api-cli run update-module --data '{"module_url":"ghcr.io/mrmarkuz/immich:1.0.4-dev.1","instances":["immich1"]}'
Thanks for pointing to the new version.
Works for me, upgraded. No issues in the logs, normal behaviour. Will await backup tonight.
Thanks, I’m going to release when the backup is working.
New backup: works
Restore in place: works
Restore as new: works
Thanks, 1.0.4 is released.
Upgraded from 1.0.4-dev to 1.0.4 production. Works.
Many thanks @mrmarkuz !
FYI
Current version and available version:
Where v1.137.0 had ‘breaking changes’ again.
TIA
Here’s the new 1.137.3 testing version. The update worked without issues.
Install:
add-module ghcr.io/mrmarkuz/immich:1.0.5-dev.1
Update:
api-cli run update-module --data '{"module_url":"ghcr.io/mrmarkuz/immich:1.0.5-dev.1","instances":["immich1"]}'
Same here, update went smooth. No issues in any log.
Thanks!
Update done and everything works good. No problems…
Thanks for testing guys!
Released: Release 1.0.5 · mrmarkuz/ns8-immich · GitHub
Immich is continiously receiving updates and thus new releases. We don’t need to be on the latest and greatest, but I am not sure how many releases we can skip to be able to upgrade to the latest?
Just thinking out loud.
I was busy with relocation but should be finished tomorrow, so updates will be released regularly again.
Please don’t get me wrong, it is just the pase of updates and releases of Immich is insane, so keeeping up with that is madness. Hence my thinking on when do we really need to upgrade.
Usually minor updates shouldn’t be an issue but you’re right, there could be some point where the direct update isn’t easily possible anymore.
It’s not a big effort to update apps, renovate is very helpful and opens PRs when there’s a new update, see for example Update ghcr.io/immich-app/immich-server Docker tag to v1.140.1 by renovate[bot] · Pull Request #12 · mrmarkuz/ns8-immich · GitHub
