HOWTO: Use SSL/port 465 in smarthost
Smarthost currently doesn’t permit to use port 465 with SSL to connect to a SMTP server:
Tested in Nethserver V6.8 with Aruba SMTP server
Maybe works in Nethserver V7 too
2017.06.21 EDIT: Yes, it works in v7 too
This is the solution:
Install stunnel:
yum install stunnel
Create a stunnel file configuration:
vi /etc/stunnel/stunnel.conf
With these lines
output=/var/log/stunnel
[smtp-tls-wrapper]
accept=127.0.0.1:11125
client=yes
connect=Your.ISP.SMTP.Server:465
Where Your.ISP.SMTP.Server is the SMTP server of your ISP
Create a file
vi /etc/rc.d/init.d/stunnel
With these lines
#!/bin/bash
# Init Script to run stunnel in daemon mode at boot time.
# Author: Riccardo Riva - RPM S.r.l.
# Revision 1.0  -  2010 November, 11
# Revision 1.1 - 2015 September, 21
# Changed definition of SEXE variable to find automatically the path of stunnel
# Run level information:
# chkconfig: 2345 99 99
# description: Secure Tunnel
# processname: stunnel
# Run "/sbin/chkconfig --add stunnel" to add the Run levels.
# This will setup the symlinks and set the process to run at boot.
# Paths and variables and system checks.
# Source function library
. /etc/rc.d/init.d/functions
# Check that networking is up.
[ ${NETWORKING} ="yes" ] || exit 0
# Path to the executable.
SEXE=`which stunnel`
# Path to the configuration file.
CONF=/etc/stunnel/stunnel.conf
# Check the configuration file exists.
if [ ! -f $CONF ]
then
	echo "The configuration file cannot be found!"
	exit 0
fi
# Path to the lock file.
LOCK_FILE=/var/lock/subsys/stunnel
# Run controls:
prog=$"stunnel"
RETVAL=0
# Start stunnel as daemon.
start() {
	if [ -f $LOCK_FILE ]
	then
		echo "stunnel is already running!"
		exit 0
	else
		echo -n $"Starting $prog: "
		$SEXE $CONF
	fi
	RETVAL=$?
	[ $RETVAL -eq 0 ] && success
	echo
	[ $RETVAL -eq 0 ] && touch $LOCK_FILE
	return $RETVAL
# Stop stunnel.
stop() {
	if [ ! -f $LOCK_FILE ]
	then
		echo "stunnel is not running!"
		exit 0
	else
		echo -n $"Shutting down $prog: "
		killproc stunnel
		RETVAL=$?
		[ $RETVAL -eq 0 ]
		rm -f $LOCK_FILE
		echo
		return $RETVAL
	fi
# See how we were called.
case "$1" in
	start)
		start
	stop)
		stop
	restart)
		stop
		start
	condrestart)
		then
			stop
			start
			RETVAL=$?
		fi
	status)
		status stunnel
		RETVAL=$?
		echo $"Usage: $0 {start|stop|restart|condrestart|status}"
		RETVAL=1
esac
exit $RETVAL
Then chmod it:
chown root:root /etc/rc.d/init.d/stunnel
chmod 755 /etc/rc.d/init.d/stunnel
And make it starting at boot:
chkconfig stunnel on
Start the service:
service stunnel start
In dashboard -> Email -> tab “Messages” -> check "Send using a smarthost"
then:
  • Hostname: 127.0.0.1
  • Port: 11125
  • Username: put the username of Your ISP SMTP Server
  • Password: put the password of Your ISP SMTP Server
  • Allow unencrypted connections: checked
Then click to “Submit”
Et Voila’, all works!
If some parameters of your ISP SMTP server changed, remember to modify the /etc/stunnel/stunnel.conf file then restart stunnel with the command
service stunnel restart
Thanks @saitobenkei many people asked that in the past.
Thanks for this howto. This is not a missed feature but a real bug @dev_team
In this world all protocols must be encrypted
Thanks @saitobenkei for the how to!
@stephdl I think it’s a bug on the provider’s side :innocent:
The 465 is deprecated since long time. It should be a last resort for legacy clients, not legacy the only one available on modern servers!
465 is deprecated but works well, and in some cases and configuration is mandatory utilize it.
Read my whining here :slight_smile:
http://community.nethserver.org/t/getmail-attachments/6650/8?u=saitobenkei
