mrmarkuz
(Markus Neuberger)
45
Got two more mirrors:
http://buck.goip.de/nethserver
This is a raspberry, a poor man’s mirror
A good old friend @neocortex sponsored another Nethserver mirror so I setup a Nethserver 7.3 on his managed host:
http://smart-ict.services/mirror/nethserver
https://smart-ict.services/mirror/nethserver
All mirrors are at least upgradeable to 100GB disk capacity for slow updates. Even the raspi may use 128GB FAT formatted sd card.
giacomo
(Giacomo Sanchietti)
46
Excellent, thank you @neocortex !!
I think this week @davidep will had mirrors to the list.
davidep
(Davide Principi)
47
Both were added!
Thank you @mrmarkuz & @neocortex
mrmarkuz
(Markus Neuberger)
48
The domain name of the mirror smart-ict.services
has changed.
The new name is:
http://nethserver.globalcortex.net/mirror/nethserver/
Thanks in advance, I am sorry for any inconvenience…
fausp
(fpausp)
49
I would like to build up a local mirror. I just installed one and it looks vy nice…
What command should I use to update my servers in the private Network?
mrmarkuz
(Markus Neuberger)
50
You may edit /etc/yum.repos.d/NethServer.repo
, comment out mirrorlist and add your own baseurl:
#mirrorlist=http://mirrorlist.nethserver.org/?release=$releasever&repo=base&arch=$basearch&nsrelease=$nsrelease
#baseurl=http://mirror.nethserver.org/nethserver/$releasever/base/$basearch/
baseurl=http://neth.local.domain.or.ip/nethserver/$releasever/base/$basearch/
fausp
(fpausp)
51
Thank you Markus, it works…
What do you think, how much space would it need to have all the other repos to be as much self-sufficient as possible ?
davidep
(Davide Principi)
52
I created a mirror. http://ketrax.eu/nethserver/
How to publish it?
Thanks
giacomo
54
Thank you so much!
For now it’s inside mirmon to monitor it: the status of nethserver.org mirrors
If the mirror is table we will add it to the list in few days!
giacomo
56
Added also this one on mirmon
giacomo
57
Your new mirrors have been added!
Thank you again @Krajczar_Jeno!
mrmarkuz
(Markus Neuberger)
58
I got a new VPS and like to replace a Nethserver mirror:
mrmarkuz.dynu.net/nethserver replaces nethserver.globalcortex.net which unfortunately is not maintained anymore.
The new server is located in Germany (contabo).
davidep
(Davide Principi)
59
Hi all.
I have seen at http://mirror-status.nethserver.org/ that the mirror I have (http://mirror.pcxlan.es), appears as an http connection, and not https, as it is available. Could you change it too, please?
Greetings.
ibinetwork
(Rafael Tavares)
62
Hi all.
I am create 3 mirrors on Brazil
Please add
ns-mirror1.ibi.net.br
ns-mirror2.ibi.net.br
ns-mirror3.ibi.net.br
Thanks for all.
davidep
(Davide Principi)
63
Can you do it by yourself? Please follow the instructions here!
https://github.com/NethServer/mirrorlist/blob/master/README.md
ibinetwork
(Rafael Tavares)
64
I am need to create a pull request?
