How to create your own NethServer mirror
deployment
devcorner
intermediate
community
mirror
(Davide Principi) #65
Yes you do!
(Rafael Tavares) #66
Pull request created
:wink:
(Davide Principi) #67
Thank you for donating your mirrors! First, let’s monitor them for a while: we can check their status here http://mirror-status.nethserver.org/. Then we’ll merge the PR.
(Rafael Tavares) #68
If possible, and the mirror is approved, add the official list before upgrades to nethserver 7.6. This makes it easier for Brazilians to update their facilities.
thank you :wink:
(Davide Principi) #69
Yes, it’s ok, approved :smile:
I’m going to merge it before 7.6!
(Davide Principi) #70
They have been merged today! Thanks again!
(Rob Bosch) #71
Just a question. How much diskspace will a mirror need? I am thinking of adding one, but my VPS has limited diskspace and I don’t want to run out of diskspace.
(Markus Neuberger) #72
Actually a mirror needs 3 GB.
(Rob Bosch) #73
Thnx for the info. Then it should be possible to add one more mirror. My VPS has 300GB diskspace…
First sync is running. In a few minutes nethserver.interlin.nl/nethserver will be available as mirror.
The server is located in Germany (Contabo VPS with 100Mb up/down link.)
(maybe it’s DNS that is not propagated yet, I thinkn the virtual host rule does not work as expected because I am ending up at default NS page and not the mirror page when I go to that url)
(Markus Neuberger) #74
This is my /etc/httpd/conf.d/mirror-nethserver.conf but I don’t use a subdomain:
Alias /mirror "/var/www/repos"
Alias /nethserver "/var/www/repos/nethserver"
<Directory /var/www/repos>
    Options +Indexes
    Options +FollowSymLinks
    Order allow,deny
    Allow from all
</Directory>
You may use httpd -S to check the used vhosts.
(Rob Bosch) #75
Hi @mrmarkuz
I followed the instructions from the first post by @giacomo
My conf file is using a subdomain:
<VirtualHost *:80>
ServerName nethserver.interlin.nl
DocumentRoot "/var/www/repos"
    Options +Indexes
    Order allow,deny
    Allow from all
</Directory>
</VirtualHost>
When I do an httpd -S I get:
httpd -S
[Tue Dec 04 21:05:11.967889 2018] [so:warn] [pid 22008] AH01574: module php5_module is already loaded, skipping
VirtualHost configuration:
*:80 is a NameVirtualHost
default server nethserver.interlin.nl (/etc/httpd/conf.d/mirror-nethserver.conf:1)
port 80 namevhost nethserver.interlin.nl (/etc/httpd/conf.d/mirror-nethserver.conf:1)
port 80 namevhost ns7.interlin.nl (/etc/httpd/conf.d/virtualhosts.conf:12)
port 80 namevhost pod.interlin.nl (/etc/httpd/conf.d/zzz_diaspora.conf:3)
*:443 is a NameVirtualHost
default server ns7.interlin.nl (/etc/httpd/conf.d/ssl.conf:56)
port 443 namevhost ns7.interlin.nl (/etc/httpd/conf.d/ssl.conf:56)
port 443 namevhost pod.interlin.nl (/etc/httpd/conf.d/zzz_diaspora.conf:9)
ServerRoot: “/etc/httpd”
Main DocumentRoot: “/var/www/html”
Main ErrorLog: “/etc/httpd/logs/error_log”
Mutex ssl-stapling: using_defaults
Mutex proxy: using_defaults
Mutex authn-socache: using_defaults
Mutex ssl-cache: using_defaults
Mutex default: dir="/run/httpd/" mechanism=default
Mutex mpm-accept: using_defaults
Mutex authdigest-opaque: using_defaults
Mutex proxy-balancer-shm: using_defaults
Mutex rewrite-map: using_defaults
Mutex authdigest-client: using_defaults
PidFile: “/run/httpd/httpd.pid”
Define: _RH_HAS_HTTPPROTOCOLOPTIONS
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“apache” id=xx
Group: name=“apache” id=xx
(Markus Neuberger) #76
You may try to remove the virtualhost lines and/or add alias / /var/www/repos.
See How to create your own NethServer mirror
Edit:
http://nethserver.interlin.nl/nethserver works!
(Rob Bosch) #77
Cool… so my mirror is up and running… :slight_smile:
@davidep can you add http://nethserver.interlin.nl/nethserver/ as mirror to the list?
The server is located in Germany (hosted by Contabo) with 100Mb up/down connection.
/edit: created PR to add the mirror
/edit2: how long does it take for a new server to show up in mirmon?
I received a message from @davidep that the cronjob might not be running, since the timestamp is not updated. How can I check if it is running?
(Markus Neuberger) #78
Seems to be running now:
Or check the logfile: /var/log/cron
(Rob Bosch) #79
I ran a manual update by issueing a /usr/local/sbin/sync-nethserver-mirrors
I don’t see any entries in cron.log about updating the mirror dir…
content of sync-nethserver-mirror in /etc/cron.d/
cat sync-nethserver-mirrors
RANDOM_DELAY=10
CRON_TZ=UTC
0 0,6,12,18 * * *root/usr/local/sbin/sync-nethserver-mirrors
(Markus Neuberger) #80
It’s only shown in cron log if it’s triggered by cron.
Did you restart cron?
systemctl restart crond
(Rob Bosch) #81
I just did and now this line shows in cron.log:
(CRON) bad command (/etc/cron.d/sync-nethserver-mirrors)
syntax error in that file?
(Markus Neuberger) #82
Don’t know if discourse eats some chars but there has to be a space between the third asterisk and root and before the path…
(Rob Bosch) #83
It was those 2 spaces between * and root and between root and /usr
I restarted cron again and now I don’t get the error message
Looks like the spaces were discarded when the file was created…
(Filippo Carletti) #84
BTW, there’s no need to restart crond, it re-reads its files automatically. Keep an eye on /var/log/cron to spot errors. Usually it needs a few seconds (max 60) to print something.
