Help to configure PPPoE
I have Century Link Fiber so checked this topic if I need to setup PPPOE now that i install the OS I need to run each command one at a time is that current?
This is how:
  1. Setting up PPPoE Interface via WebGUI
  2. Typing this parameteres to the command line:
db networks set eth1.201 vlan role pppoe
db networks settype ppp0 xdsl
db networks setprop ppp0 role red user myusername Password mypassword
signal-event interface-update
db networks setprop eth1 role ‘’
@davidep
Can you help him?
Hi @Angelo_Restrepo and welcome to NethServer community.
If I remember correctly, the PPPoE configuration is available from the Nethgui UI only (https port 980)
https://docs.nethserver.org/en/v7/base_system.html?highlight=pppoe#logical-interfaces
Once it is configured from the Nethgui UI, no additional setup should be needed.
I hope it helps!
Hello,
Davide Principi |
I had the OS installed on unattended case that was the only way I could install it on my system. Then I went and typed network-recovery and assigned 192.168.1.1 but I could not connect to the GUI with the port you mentioned I most be missing a speed to get to the GUI.
