I installed nethserver docker and portainer which I think is great instead of having docker in standalone package. Nethserver = Management all in one roof
Problem I have I have made docker a swarm cluster by docker swarm init as I want this system as a cluster for scalability.
Problem is when I have swarm installed I receive errors in my shorewell look at the following
when I remove docker and flush the iptables the problem goes away I think I have to create the network ingress on nethserver but one im not sure if that’s the case and two I don’t know how to do that.
Can someone point me into the right direction please
I think the bridge network needs to be attachable too to attach the external sources to like wordpress stack to the bridge too once the stack has been created on the swarm
I don’t know how Docker swarm works; having said that, the nethserver-docker rpm is just an experiment to run some docker applications within a NethServer host. It disables the docker iptables mangling because NethServer firewall configuration is handled by Shorewall.
Maybe I’m wrong but this makes NethServer not compatible with some assumptions of docker swarm.
I have docker and portainer installed outside of nethserver on the same machine and the swarm and shorewall work no errors.
But i think that is because nethserver portainer deploys as a container.
but when in swarm you need to deploy portainer as a service which i have done.
Maybe you can make two deployment repos in you upstream one for normal deployment and one for swarm as portainer needs to be deployed differently in both scenarios
