Yes of course but it doesn’t work.
Here is the system info
<details><summary>Informazioni sul sistema, l'installazione e la configurazione</summary><pre>GLPI 10.0.12 ( => /var/www/html/glpi)
Installation mode: TARBALL
Current language:it_IT
</pre></details><details><summary>Server</summary><pre>
Operating system: Linux glpi 5.14.0-427.16.1.el9_4.x86_64 #1 SMP PREEMPT_DYNAMIC Wed May 8 17:48:14 UTC 2024 x86_64
PHP 8.2.18 apache2handler (Core, FFI, PDO, Phar, Reflection, SPL, SimpleXML, Zend OPcache, apache2handler, bz2, calendar, ctype,
curl, date, dom, exif, fileinfo, filter, ftp, gd, gettext, hash, iconv, igbinary, imap, intl, json, ldap, libxml, mbstring,
mysqli, mysqlnd, openssl, pcre, pdo_mysql, posix, random, readline, redis, session, shmop, sockets, sodium, standard, sysvmsg,
sysvsem, sysvshm, tokenizer, xml, xmlreader, xmlrpc, xmlwriter, xsl, zip, zlib)
Setup: max_execution_time="600" memory_limit="64M" post_max_size="8M" safe_mode="" session.save_handler="files"
upload_max_filesize="2M" disable_functions=""
Software: Apache/2.4.59 (Debian) (Apache/2.4.59 (Debian) Server at inquad.duckdns.org Port 80
Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.5 Safari/605.1.15
Server Software: mariadb.org binary distribution
Server Version: 10.11.5-MariaDB-1:10.11.5+maria~ubu2204
Server SQL Mode: STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION
Parameters: glpi@127.0.0.1:3306/glpi
Host info: 127.0.0.1 via TCP/IP
PHP version (8.2.18) is supported.
Sessions configuration is OK.
Allocated memory is sufficient.
mysqli extension is installed.
Following extensions are installed: dom, fileinfo, filter, libxml, json, simplexml, xmlreader, xmlwriter.
curl extension is installed.
gd extension is installed.
intl extension is installed.
zlib extension is installed.
The constant SODIUM_CRYPTO_AEAD_XCHACHA20POLY1305_IETF_NPUBBYTES is present.
Database engine version (10.11.5) is supported.
No files from previous GLPI version detected.
The log file has been created successfully.
Write access to /var/www/html/glpi/files/_cache has been validated.
Write access to /var/www/html/glpi/files/_cron has been validated.
Write access to /var/www/html/glpi/files has been validated.
Write access to /var/www/html/glpi/files/_dumps has been validated.
Write access to /var/www/html/glpi/files/_graphs has been validated.
Write access to /var/www/html/glpi/files/_lock has been validated.
Write access to /var/www/html/glpi/files/_pictures has been validated.
Write access to /var/www/html/glpi/files/_plugins has been validated.
Write access to /var/www/html/glpi/files/_rss has been validated.
Write access to /var/www/html/glpi/files/_sessions has been validated.
Write access to /var/www/html/glpi/files/_tmp has been validated.
Write access to /var/www/html/glpi/files/_uploads has been validated.
Web server root directory configuration seems safe.
Sessions configuration is secured.
OS and PHP are relying on 64 bits integers.
exif extension is installed.
ldap extension is installed.
openssl extension is installed.
Following extensions are installed: bz2, Phar, zip.
Zend OPcache extension is installed.
Following extensions are installed: ctype, iconv, mbstring, sodium.
Write access to /var/www/html/glpi/marketplace has been validated.
Access to timezone database (mysql) is not allowed.
</pre></details><details><summary>GLPI constants</summary><pre>
GLPI_ROOT: "/var/www/html/glpi"
GLPI_CONFIG_DIR: "/var/www/html/glpi/config"
GLPI_VAR_DIR: "/var/www/html/glpi/files"
GLPI_MARKETPLACE_DIR: "/var/www/html/glpi/marketplace"
GLPI_USE_CSRF_CHECK: "1"
GLPI_CSRF_EXPIRES: "7200"
GLPI_CSRF_MAX_TOKENS: "100"
GLPI_USE_IDOR_CHECK: "1"
GLPI_IDOR_EXPIRES: "7200"
GLPI_ALLOW_IFRAME_IN_RICH_TEXT: false
GLPI_SERVERSIDE_URL_ALLOWLIST: ["/^(https?|feed):\\/\\/[^@:]+(\\/.*)?$/"]
GLPI_TELEMETRY_URI: "https://telemetry.glpi-project.org"
GLPI_INSTALL_MODE: "TARBALL"
GLPI_NETWORK_MAIL: "glpi@teclib.com"
GLPI_NETWORK_SERVICES: "https://services.glpi-network.com"
GLPI_MARKETPLACE_ALLOW_OVERRIDE: true
GLPI_MARKETPLACE_MANUAL_DOWNLOADS: true
GLPI_USER_AGENT_EXTRA_COMMENTS: ""
GLPI_DISABLE_ONLY_FULL_GROUP_BY_SQL_MODE: "1"
GLPI_AJAX_DASHBOARD: "1"
GLPI_CALDAV_IMPORT_STATE: 0
GLPI_DEMO_MODE: "0"
GLPI_CENTRAL_WARNINGS: "1"
GLPI_TEXT_MAXSIZE: "4000"
GLPI_DOC_DIR: "/var/www/html/glpi/files"
GLPI_CACHE_DIR: "/var/www/html/glpi/files/_cache"
GLPI_CRON_DIR: "/var/www/html/glpi/files/_cron"
GLPI_DUMP_DIR: "/var/www/html/glpi/files/_dumps"
GLPI_GRAPH_DIR: "/var/www/html/glpi/files/_graphs"
GLPI_LOCAL_I18N_DIR: "/var/www/html/glpi/files/_locales"
GLPI_LOCK_DIR: "/var/www/html/glpi/files/_lock"
GLPI_LOG_DIR: "/var/www/html/glpi/files/_log"
GLPI_PICTURE_DIR: "/var/www/html/glpi/files/_pictures"
GLPI_PLUGIN_DOC_DIR: "/var/www/html/glpi/files/_plugins"
GLPI_RSS_DIR: "/var/www/html/glpi/files/_rss"
GLPI_SESSION_DIR: "/var/www/html/glpi/files/_sessions"
GLPI_TMP_DIR: "/var/www/html/glpi/files/_tmp"
GLPI_UPLOAD_DIR: "/var/www/html/glpi/files/_uploads"
GLPI_INVENTORY_DIR: "/var/www/html/glpi/files/_inventories"
GLPI_NETWORK_REGISTRATION_API_URL: "https://services.glpi-network.com/api/registration/"
GLPI_MARKETPLACE_PLUGINS_API_URI: "https://services.glpi-network.com/api/marketplace/"
GLPI_I18N_DIR: "/var/www/html/glpi/locales"
GLPI_VERSION: "10.0.12"
GLPI_SCHEMA_VERSION: "10.0.12@b902ef5f5da967c1a9d0826ee8a7dce07d57cf3d"
GLPI_MARKETPLACE_PRERELEASES: false
GLPI_MIN_PHP: "7.4.0"
GLPI_MAX_PHP: "8.4.0"
GLPI_YEAR: "2024"
</pre></details><details><summary>Libraries</summary><pre>
htmlawed/htmlawed version 1.2.14 in (/var/www/html/glpi/vendor/htmlawed/htmlawed)
phpmailer/phpmailer version 6.8.0 in (/var/www/html/glpi/vendor/phpmailer/phpmailer/src)
simplepie/simplepie version 1.5.8 in (/var/www/html/glpi/vendor/simplepie/simplepie/library)
tecnickcom/tcpdf version 6.4.4 in (/var/www/html/glpi/marketplace/pdf/vendor/tecnickcom/tcpdf)
michelf/php-markdown in (/var/www/html/glpi/vendor/michelf/php-markdown/Michelf)
true/punycode in (/var/www/html/glpi/vendor/true/punycode/src)
iamcal/lib_autolink in (/var/www/html/glpi/vendor/iamcal/lib_autolink)
sabre/dav in (/var/www/html/glpi/vendor/sabre/dav/lib/DAV)
sabre/http in (/var/www/html/glpi/vendor/sabre/http/lib)
sabre/uri in (/var/www/html/glpi/vendor/sabre/uri/lib)
sabre/vobject in (/var/www/html/glpi/vendor/sabre/vobject/lib)
laminas/laminas-i18n in (/var/www/html/glpi/vendor/laminas/laminas-i18n/src)
laminas/laminas-servicemanager in (/var/www/html/glpi/vendor/laminas/laminas-servicemanager/src)
monolog/monolog in (/var/www/html/glpi/vendor/monolog/monolog/src/Monolog)
sebastian/diff in (/var/www/html/glpi/vendor/sebastian/diff/src)
donatj/phpuseragentparser in (/var/www/html/glpi/vendor/donatj/phpuseragentparser/src/UserAgent)
elvanto/litemoji in (/var/www/html/glpi/vendor/elvanto/litemoji/src)
symfony/console in (/var/www/html/glpi/vendor/symfony/console)
scssphp/scssphp in (/var/www/html/glpi/vendor/scssphp/scssphp/src)
laminas/laminas-mail in (/var/www/html/glpi/vendor/laminas/laminas-mail/src/Protocol)
laminas/laminas-mime in (/var/www/html/glpi/vendor/laminas/laminas-mime/src)
rlanvin/php-rrule in (/var/www/html/glpi/vendor/rlanvin/php-rrule/src)
ramsey/uuid in (/var/www/html/glpi/vendor/ramsey/uuid/src)
psr/log in (/var/www/html/glpi/vendor/psr/log/Psr/Log)
psr/simple-cache in (/var/www/html/glpi/vendor/psr/simple-cache/src)
psr/cache in (/var/www/html/glpi/vendor/psr/cache/src)
league/csv in (/var/www/html/glpi/vendor/league/csv/src)
mexitek/phpcolors in (/var/www/html/glpi/vendor/mexitek/phpcolors/src/Mexitek/PHPColors)
guzzlehttp/guzzle in (/var/www/html/glpi/vendor/guzzlehttp/guzzle/src)
guzzlehttp/psr7 in (/var/www/html/glpi/vendor/guzzlehttp/psr7/src)
glpi-project/inventory_format in (/var/www/html/glpi/vendor/glpi-project/inventory_format/lib/php)
wapmorgan/unified-archive in (/var/www/html/glpi/vendor/wapmorgan/unified-archive/src)
paragonie/sodium_compat in (/var/www/html/glpi/vendor/paragonie/sodium_compat/src)
symfony/cache in (/var/www/html/glpi/vendor/symfony/cache)
html2text/html2text in (/var/www/html/glpi/vendor/html2text/html2text/src)
symfony/css-selector in (/var/www/html/glpi/vendor/symfony/css-selector)
symfony/dom-crawler in (/var/www/html/glpi/vendor/symfony/dom-crawler)
twig/twig in (/var/www/html/glpi/vendor/twig/twig/src)
twig/string-extra in (/var/www/html/glpi/vendor/twig/string-extra)
symfony/polyfill-ctype not found
symfony/polyfill-iconv not found
symfony/polyfill-mbstring not found
symfony/polyfill-php80 not found
symfony/polyfill-php81 not found
symfony/polyfill-php82 in (/var/www/html/glpi/vendor/symfony/polyfill-php82)
league/oauth2-client in (/var/www/html/glpi/vendor/league/oauth2-client/src/Provider)
league/oauth2-google in (/var/www/html/glpi/vendor/league/oauth2-google/src/Provider)
thenetworg/oauth2-azure in (/var/www/html/glpi/vendor/thenetworg/oauth2-azure/src/Provider)
</pre></details><details><summary>SQL replicas</summary><pre>
Not active
</pre></details><details><summary>Notifications</summary><pre>
Way of sending emails: PHP
</pre></details><details><summary>Plugins list</summary><pre>
barcode Name: Barcode Version: 2.7.1 State: Enabled
Install Method: Marketplace
camerainput Name: Camera Input Version: 2.1.0 State: Enabled
pdf Name: Stampa in PDF Version: 3.0.0 State: Enabled
</pre></details>```
