HEllo @france on our latest test
adding a fresh instance, the correct glpi denotes the correct version of glpi.
It seems the record for your case, has persisted in the database.
It wouldn’t be the first time that a browser cache is playing tricks…
Hello , if I understand correctly you say to create a new instance. But if I create a new instance the data and the paameters of the previous version, do I lose them? It also seems that I always have the strangest problems. … …
Not necessarily, i was meerely testing to understand your issue, and to ascertain if the application is latest or now.
You will definitely not gain your data if you re-install, unless a backup of the individual database and volumes as well as env is made, and restored
Okay, I remember in the old versions of GLPI , there was the option to export or rather back up glpi data by default. This operation worked very well.
