Mat78
(Matteo)
July 6, 2018, 2:49pm
1
i’ve installed Nethserver for Fileserver and PBX purposes.
Fileserver seems to works perfectly.
I’ve had some problem with FreePBX: I’ve installed the packages and everything seems to works, but when I try to update the system it doesn’t work and I get this error message:
Environment & details:
GET Data
display modules
action process
quietmode 1
online 1
modules Array ( [core] => Array ( [action] => install [track] => stable ) )
POST Data empty
Files empty
Cookies
lang it_IT
searchHide 1
PHPSESSID ok6lofc3iovqmna36t7ks9mrk2
_ga GA1.1.440033766.1530716374
_gid GA1.1.1908166959.1530804096
nethgui ml3ohg17uieufq0e8cpuddfcn7
Session
langdirection ltr
module_name modules
module_page modules
AMP_user ampuser Object ( [username] => Voip-Admin [id] => [password:ampuser:private] => e82edf4c027f3db0e03668bb3580d850947cd03e [extension_high:ampuser:private] => [extension_low:ampuser:private] => [sections:ampuser:private] => Array ( [0] => * ) [mode:ampuser:private] => database [opmode:ampuser:private] => [lang] => [tz] => [dateformat] => [timeformat] => [datetimeformat] => [_lastactivity] => 1530887990 )
Server/Request Data
LANG en_US.UTF-8
PATH /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
NOTIFY_SOCKET /run/systemd/notify
USER asterisk
HOME /home/asterisk
FCGI_ROLE RESPONDER
UNIQUE_ID Wz9-Nu4ve8EtJ8Cd85ABcwAAAAo
HTACCESS on
HTTP_HOST 192.168.100.2
HTTP_ORIGIN https://192.168.100.2
HTTP_USER_AGENT Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36
HTTP_ACCEPT */*
HTTP_REFERER https://192.168.100.2/freepbx/admin/config.php?display=modules
HTTP_ACCEPT_ENCODING gzip, deflate, br
HTTP_ACCEPT_LANGUAGE it-IT,it;q=0.9,en-US;q=0.8,en;q=0.7
HTTP_COOKIE lang=it_IT; searchHide=1; PHPSESSID=ok6lofc3iovqmna36t7ks9mrk2; _ga=GA1.1.440033766.1530716374; _gid=GA1.1.1908166959.1530804096; lang=it_IT; nethgui=ml3ohg17uieufq0e8cpuddfcn7
HTTP_X_FORWARDED_FOR 192.168.100.102
HTTP_X_FORWARDED_HOST 192.168.100.2
HTTP_X_FORWARDED_SERVER server.SuperComprensorioMi2.local
HTTP_CONNECTION Keep-Alive
CONTENT_LENGTH 0
SERVER_SIGNATURE
SERVER_SOFTWARE Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/5.4.16
SERVER_NAME 192.168.100.2
SERVER_ADDR 127.0.0.1
SERVER_PORT 80
REMOTE_ADDR 127.0.0.1
Can someone help me solve this problem?
Thank you in advance
mrmarkuz
(Markus Neuberger)
July 7, 2018, 7:40pm
2
Did you get an error message like this? The real error is shown on the top left side.
It’s just a permission problem, so let’s set asterisk as owner with the following command:
chown asterisk:asterisk /etc/asterisk/http_custom.conf
Now the update should work.
giacomo
(Giacomo Sanchietti)
July 7, 2018, 8:44pm
3
Maybe @Stll0 already faced such problem?
mrmarkuz
(Markus Neuberger)
July 7, 2018, 9:17pm
4
We already had this issue:
Tried to online-upgrade some Modules and run into this Bug:
[image]
In this case it seems to be just one file but I am afraid that future freepbx module updates may lead to similar errors.
Stll0
(Stefano Fancello)
July 9, 2018, 6:46am
5
I don’t get the error. Try to update FreePBX modules from command line
scl enable rh-php56 -- fwconsole ma updateall
fausp
(fpausp)
July 13, 2018, 4:40am
6
Looks good !
[root@infra02 ~]# scl enable rh-php56 -- fwconsole ma updateall
No repos specified, using: [standard] from last GUI settings
Module(s) requiring upgrades: conferences, core, soundlang, userman, voicemail
Upgrading module 'core' from 14.0.18.18 to 14.0.18.22
Downloading module 'core'
Processing core
Downloading...
1107573/1107573 [============================] 100%
Finished downloading
Extracting...Done
Download completed in 3 seconds
Updating tables trunks, pjsip, sip, dahdi, iax, indications_zonelist, devices, users, incoming, outbound_routes, dahdichandids, o utbound_route_patterns, outbound_route_sequence, outbound_route_trunks, outbound_routes, trunk_dialpatterns...Done
Migrating pickup groups to named pickup groups
Migrating call groups to named call groups
Checking for possibly invalid emergency caller id fields..none found
Migrating old media encryption values...done
Generating CSS...Done
Module core successfully installed
Updating Hooks...Done
Upgrading module 'conferences' from 13.0.23.11 to 13.0.23.12
Downloading module 'conferences'
Processing conferences
Downloading...
92757/92757 [============================] 100%
Extracting...Done
Module conferences successfully installed
Upgrading module 'soundlang' from 14.0.4.5 to 14.0.4.6
Downloading module 'soundlang'
Processing soundlang
Downloading...
105155/105155 [============================] 100%
Extracting...Done
Download completed in 2 seconds
Updating tables soundlang_packages, soundlang_settings, soundlang_customlangs, soundlang_prompts...Done
Installing/updating packages for en...Done
Module soundlang successfully installed
Upgrading module 'userman' from 14.0.3.40 to 14.0.3.41
Downloading module 'userman'
Processing userman
Downloading...
377475/377475 [============================] 100%
Extracting...Done
Updating tables userman_users, userman_users_settings, userman_groups, userman_groups_settings, userman_directories...Done
Module userman successfully installed
Upgrading module 'voicemail' from 14.0.1.25 to 14.0.1.26
Downloading module 'voicemail'
Processing voicemail
Downloading...
573820/573820 [============================] 100%
Extracting...Done
Download completed in 4 seconds
Checking for General Setting migrations..not needed
checking if Voicemail Admin (vmailadmin) is installed..not installed, ok
Module voicemail successfully installed
All upgrades completed successfully!
