continuous free space problem on the board … This is my second server, the first could not retrieve it because I get to 100%, How can I increase the space?
[root@nethserver ~]# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/VolGroup-lv_root
46G 43G 1.3G 98% /
tmpfs 1.5G 0 1.5G 0% /dev/shm
/dev/md1 496M 65M 406M 14% /boot
We start moving from zentyal server, basics network (1 lan, 2 wan),balance, proxy, dhcp, dns, firewall … This is the 2st server in 24hrs with the same problem
log nmbd looks like a good place to start to look for repeating messages and errors, though I wouldn’t try to open a file that big.
Maybe give us a screenshot of your dashboard on the gui page so we can see your basic setup, black out anything you think you don’t want to share, ip, domain, whatever.
You’re going to have to tell us what your doing in some detail if we’re to help you quickly without playing 40 questions.
Ok, well, plain installs of NS don’t fill up logs so you’ll want to review your logs from the gui and watch your log sizes from the cli as you add modules so you can narrow down what, in your setup, is unhappy.
