Where I can find, on Nethserver, the file that keep all the entries for the A records I’ve listed using the Microsoft DNS Manager? there is a way then to modify these entries directly on Nethserver and see changes on Microsoft DNS Manager?
The AD specific DNS records are not stored in a file, they are stored in LDAP (AD is a “propreity” LDAP).
On NethServer, they can be created or modified by using PHPLDAPAdmin, from Stephdl, see here:
I use PHPLDAPadmin - in kamikaze mode - once in a while. An AD doesn’t need that much “administration”, once it’s set up. Basically remove a host, add a host. Same for users. Groups are less needed later on, unless someone creates a new division in the company.
But it is easier to handle than MS-RSAT when it comes to removing a host from AD…
“Kamikaze” is just to indicate that you should know what you’re doing - at least with AD!
MS-RSAT doesn’t give off a warning, but does the same things (and more!).
