jgjimenezs
(Jose G Jimenez S )
March 23, 2021, 7:10pm
1
Greetings Team @spanish_team @alefattorini , I have returned after being infected with covid-19 and my family. We have recovered although we suffered from the aftermath of it.
I will correct some translations into Spanish so that it is aesthetic and more professional for its start-up in companies.
Is it possible to expand this menu a little more?
A hug for everyone
dnutan
(Marc)
March 23, 2021, 8:57pm
2
Happy to have you back. Stay safe. Best wishes for you and your family.
jgjimenezs
(Jose G Jimenez S )
April 3, 2021, 10:56pm
4
Currently I have made progress in the Spanish translations, I hope to finish next week, and notify its completion to test the language packs.
jgjimenezs
(Jose G Jimenez S )
April 11, 2021, 12:26pm
5
A week of certifications in cisco academy and Spanish translations in NethServer.
Good week. Spanish language is ready.
Greetings to all.
jgjimenezs
(Jose G Jimenez S )
April 11, 2021, 11:58pm
6
Is it possible to extend the menu? @support_team @dev_team
mrmarkuz
(Markus Neuberger)
April 12, 2021, 12:31am
7
I think the trimming of the menu entries happens because of the scrollbar. Does it look better when the browser window has enough height so that the scrollbar won’t appear?
it’s trimmed in other languages than English. I did not find the right width in css…
jgjimenezs
(Jose G Jimenez S )
April 12, 2021, 12:40am
8
Thanks, tomorrow I will document myself in the cockpit to see what I can solve, I think something can be done otherwise I will have to modify the translations to make it shorter
jgjimenezs
(Jose G Jimenez S )
April 12, 2021, 12:19pm
10
hi @giacomo yes, it can be edited compressed css (app.7e1e2550.css.gz)
I am placing the specific line to be able to extend it
to achieve this I will notify you to do some implementation at the level of updates
jgjimenezs
(Jose G Jimenez S )
April 12, 2021, 8:10pm
11
I made a progress, when I have all the lines to edit I will send the configured file for you to test it.
jgjimenezs
(Jose G Jimenez S )
April 13, 2021, 11:51am
12
if we change this value
#navbar-left {width:auto;
Is there a way that this value comes from the factory? @dev_team
in app.7e1e2550.css we will achieve this.
I am looking for how to customize the scroll bar to be thinner
giacomo
(Giacomo Sanchietti)
April 13, 2021, 12:28pm
13
It was hard to find, but I think it comes from our css: /usr/share/cockpit/nethserver/css/app.7e1e2550.css.gz.
See also https://github.com/NethServer/nethserver-cockpit/blob/master/ui/src/styles/main.css
But I have no idea if it’s safe to change it.
jgjimenezs
(Jose G Jimenez S )
April 13, 2021, 1:42pm
14
at least change from 55px to auto
#navbar-left {
width: 55px; auto
-webkit-transition: width 0.25s ease-in-out;
-moz-transition: width 0.25s ease-in-out;
-o-transition: width 0.25s ease-in-out;
Thanks @giacomo
jgjimenezs
(Jose G Jimenez S )
April 14, 2021, 12:09am
15
@giacomo I will do some tests before to see if these changes do not affect all the structures of the applications. if they affect its graphic design I will leave it as it is.
giacomo
April 14, 2021, 2:53pm
16
@jgjimenezs I’ve create a draft package for you: https://github.com/NethServer/nethserver-cockpit/pull/327
You can test it on multiple monitor sizes.
@stephdl do we have the same problem with other languages like French?
stephdl
(Stéphane de Labrusse)
April 14, 2021, 2:57pm
17
yes with french we could increase the size of the left panel too, just a cosmetic fix…no idea how to do it
giacomo
April 14, 2021, 3:08pm
19
stephdl:
Can you please check with the package inside the PR?
stephdl
April 14, 2021, 3:15pm
20
yes it seems good what do you think @jgjimenezs
