[Errno 256] No more mirrors to try
NethServer Version: 7.6
Cannot get polkit…
[root@neth13 ~]# yum --enablerepo=* clean all && yum update -y
Error downloading packages:
      polkit-0.112-18.el7_6.1.x86_64: [Errno 256] No more mirrors to try.
Any suggestions?
Same problem here. Updated an installation without a flaw, the second one went the same way as yours.
I’ll try tomorrow if some mirrors will be updated…
I’ll do the same…
This early morning I’ve received a related message from anacron:
/etc/cron.daily/0yum-daily.cron:
Some delta RPMs failed to download or rebuild. Retrying..
Right now, on a test machine, it is getting this (excerpts):
polkit-0.112-18.el7_6.1.x86_64 FAILED
http://mirror.gadix.com/centos/7.6.1810/updates/x86_64/Packages/polkit-0.112-18.el7_6.1.x86_64.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
Trying other mirror.
Haven’t tried, but I guess the update will work by disabling deltarpms until CentOS repos are fixed.
I’ll wakeup the kitten for a shot.
And… yum update --setopt=deltarpm=0 rolled with a double six as result.
Still not possible, is someone fixing it? I would need it on Mo to be able to install a new Server with all modules/updates…
polkit reinstall succeeded here! This is my repolist -v output excerpt:
Repo-id      : ce-updates/7/x86_64
Repo-name    : CE-Updates-7.6.1810
Repo-revision: 1553029836
Repo-updated : Tue Mar 19 22:24:18 2019
Repo-pkgs    : 1,457
Repo-size    : 6.8 G
Repo-mirrors : http://mirrorlist.nethserver.org/?release=7&repo=ce-updates&arch=x86_64&nsrelease=7.6.1810
Repo-baseurl : http://mirrors.prometeus.net/centos/7.6.1810/updates/x86_64/ (9 more)
Repo-expire  : 21,600 second(s) (last: Fri Mar 22 10:11:22 2019)
  Filter     : read-only:present
Repo-filename: /etc/yum.repos.d/NethServer.repo
Did it manually:
wget http://centos.mirror.garr.it/centos/7.6.1810/updates/x86_64/Packages/polkit-0.112-18.el7_6.1.x86_64.rpm
yum localinstall polkit-0.112-18.el7_6.1.x86_64.rpm
Nevertheless, it should be fixed?
IMHO someone (in CentOS organization) should understand that DeltaRPM has to be regenerated and mirrored… anyway i were able to update when i posted the command…
Much simpler way:
yum install http://centos.mirror.garr.it/centos/7.6.1810/updates/x86_64/Packages/polkit-0.112-18.el7_6.1.x86_64.rpm
And yum localinstall is never necessary–a simple yum install does the job.
Update: This polkit issue appears to have resolved itself sometime on Saturday afternoon.
this is my netserver version (NethServer release 7.6.1810 ) but in cli ssh the system no recive update
t
rpm -e polkit --nodeps
than yum install polkit
than yum update
and all ok.
Why? The error messages (when they were happening; they appear to be resolved now) give you direct URLs to the package on any of several mirrors. All you have to do is what I posted a few days ago: yum upgrade <URL> to take care of that package, then yum upgrade again to get the rest of them.
I don’t know why, but i installed today fresh, and that come again.
After uninstall with no dependencies, and installed with “yum install polkit”, Nethserver7 installed was the version polkit-0.112-18.el7_6.1.x86_64.rpm, than worked all others.
