NethServer Version: 7.9.2009
I get several error messages:
imap(yyy@xxx): Error: /var/lib/nethserver/vmailyyy@xxx/Maildir/shared/testpostfach@politik.lokal/.INBOX/dovecot.index.pvt view is inconsistent
How to fix these?
How to fix these?
Here are some workarounds:
I have tons of such errors. Unfortunately, the overview is completely lost in such spam.
What exactly is the workaround to fix this?
I have tons of log messages:
/var/lib/nethserver/vmail/yyy@xxxxl/Maildir/public/dovecot.index.pvt view is inconsistent
The file does not exist however and the directoy only contains a file dovecot.index.pvt.log
How to solve this
BTW: What is the use of the public spam folder, which is read only and empty?
what inside
I do have for each folders
/var/lib/nethserver/vmail/user@domain/Maildir/shared/user@domain/.INBOX.Toulibre/dovecot.index.pvt
https://wiki.dovecot.org/IndexFiles
Install mlocate
, then do updatedb
, try to find locate dovecot.index.pvt
you need to get one per user folder email
binary file
https://dovecot.org/pipermail/dovecot/2019-December/117767.html
https://wiki.dovecot.org/Tools/Doveadm/Index
All errors are in folders under “shared” or “public”. Also I deleted a user, who shared the mailbox without another one, so that there are folders of the deleted user under shared.
How to tidy this up? Actually Nethserver should not leave that many garbage after deletion of users. Especially when cannot handle these non-deleted files without massive errors in the logs.
Can I just delete these folders?
Problem still there.
Did you already try the posted workarounds?
Another option could be to suppress the log entries in rsyslog like it’s done for sogo, see also SOGo — NethServer 7 Final
If you’re willing to stray away from upstream Index of /ce-2.3.19/centos/7/RPMS/x86_64/ has latest build for COS7, runs fine but needs some config mods.
Which mods exactly?
The question is whether this could introduce additional incompatibilities?
ssl_protocols setting was replaced by ssl_min_protocol
ssl_parameters was replaced with ssl_dh
SSLv2 is no longer supported as SSL protocol
ssl_min_protocol default changed to TLSv1.2, as older TLS versions are deprecated
change it to TLSv1 or TLSv1.1 if you need to support older, deprecated protocols
https://doc.dovecot.org/installation_guide/upgrading/from-2.2-to-2.3/
https://doc.dovecot.org/installation_guide/upgrading/from-2.3-to-2.3.x/
