With cockpit we now have to make some changes to display our web application inside the application menu of cockpit. You have to test and make a lot of attention to the sudoers.d/files, it could break the server-manager, so add an empty line at the end of the file, and please test it carefully delegated to a simple user.
you can use this as example
you must set as executable the api/read
Then the web app must be delegated to the group of the user if you want your user use the html link
