Cron doesn't work
Bump, also cron does not work for me. I run a script
service bl_incremental start
where bl_increment is a service i want to start every day at a certain time. crontab -l shows “no crontab for root” meaning the cron is empty.
nethserver-crontabmanager uses the system wide crontab (/etc/crontab)
Try to put the whole path to the binary and also try directly the command in the shell
Verify also that your cron job is well written in /etc/crontab
–cron for bl_incremental
40 9 * * root service bl_incremental start
also did a which systemctl and used the loaction : 40 9 * * root /usr/bin/systemctl bl_incremental start
Looks right, 9:40 as root
If it’s on Nethserver 7 the systemctl arguments are switched (systemctl start bl_incremental).
Also it’s missing the day of week definition (40 9 * * *), correct me if wrong.
“* * * * * root /etc/rc.d/init.d/bl_incremental”
I had to link directly to the script, and I was missing day and week…thanks
ok in short it doesn’t work because you don’t write the full path to the file ???
@dnutan, I would like to validate in netgui that the job starts by a full valid path to a file…
good or bad idea ?
I basically just wanted to make a cron for the firewall script. I have 2 scripts that I modified from the other thread, one for a complete redownload of blacklist ips, including ones I add and refresh/update of shorewall that runs every week and a second script that adds ips from a list I can add to from evebox and fail2ban, that runs every night, it does the same thing but without deleting the blrules file in etc/shorewall. It may have been my failure to include all the “* * * *” im not sure if crond requires all times filled with something. So it probably works fine, you just have to know cron syntax to use…which I didnt before I did this.
Well…it is for this that i created the simplified mode :slight_smile:
It could be a good idea, even though isn’t mandatory for commands in crontab’s PATH environment. Also may be hard to validate when multiple commands are concatenated. Not sure it worths the effort. :thinking:
I’d consider:
  • making command’s textarea single-line (not multi-line)
  • User field could be the same for both simplified/advanced settings
  • verify User field is not empty
  • verify time field is not empty when advanced settings are selected
  • simplified settings: verify required number of arguments are selected
A minor oddity, maybe not a problem: naming a new cronjob the same as an existing one, shows a validation error (ok) and fills empty fields of the new task with values from the existing task.
Again, it was probably my fault, Ive not really used cron before and google wasn’t giving me consistent answers :smiley:
no problem, it is time to review the code
in fact the simplified mode could be made more simpler.
we can have a drop down with
@yearly (or @annually) 	Run once a year at midnight of 1 January 	0 0 1 1 *
@monthly 	Run once a month at midnight of the first day of the month 	0 0 1 * *
@weekly 	Run once a week at midnight on Sunday morning 	0 0 * * 0
@daily 	Run once a day at midnight 	0 0 * * *
@hourly 	Run once an hour at the beginning of the hour 	0 * * * *
@reboot 	Run at startup 	N/A
after the dropdown we could add the other options to set graphically the time job and of course also create what @dnutan added
