Hello, how I can configure openvpn warior I can conect the vpn but I can get in the lan.
Could you please post the screenshots of your network configuration and VPN configuration please?
Side question: are you considering the RoadWarrior as a “external lan user” which should access to all the LAN resources?
I want to get in the lan from other place, I have put a public IP but I can´t.
I install openvpn in the other side or what program you recomend.? witch ports do I have open.?
I personally use the bridged mode for R2W, I import the .ovpn file with network-manager, basically it is all you have to do
normally with bridged you use 1194 UDP and you have a real IP on your network
What I put here…?
create a bridge (br0 for example) in the network page
here… what LAN I mark the green only or the red that is internet; if I do this don´t affect my conection.?
has any idea.?
I do not understand what you did
How many network interface do you have ?
You simply need to create a bridge like nethserver-dc does, to create a container for SAMBA AD.
Hello; I have 4 vlans… witch i have to mark.?
the one you want to have an external access I presume, just take one
but have error…
america has been discovered by an error …
why do you not use simply em2 LAN (green) ?
