Concurrent backup is running
NethServer Version: NethServer release 7.6.1810 (final)
Hello,
We have NS were we keep receiving a report that says:
Backup: backup-data
Backup started at 2019-01-08 20:00:01
Pre backup scripts status: SKIPPED (concurrent backup is running)
Another duplicity instance is already running with this archive directory
Duplicity backup failed
Action 'backup-data-duplicity ': FAIL
Backup status: FAIL
On messages log, it’s complaining about the interval time (below).
I disabled the backup and enabled back today, so not sure if that fixes the error for tonight’s backup.
Any idea, how we can fix this error.
Thank you
Jan 9 07:59:26 srv collectd[4558]: plugin_read_thread: read-function of the `df' plugin took 51.856 seconds, which is above its read interval (10.000 seconds). You might want to adjust the `Interval' or `ReadThreads' settings. Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-mnt-backup-backup-data/df_complex-free.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-mnt-backup-backup-data/df_complex-free.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-mnt-backup-backup-data/df_complex-used.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-mnt-backup-backup-data/df_complex-used.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-mnt-backup-backup-data/df_complex-reserved.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-mnt-backup-backup-data/df_complex-reserved.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401118/df_complex-reserved.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401118/df_complex-reserved.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401118/df_complex-used.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401118/df_complex-used.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401118/df_complex-free.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401118/df_complex-free.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401123/df_complex-reserved.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401123/df_complex-reserved.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401123/df_complex-used.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401123/df_complex-used.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401123/df_complex-free.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401123/df_complex-free.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401121/df_complex-free.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401121/df_complex-free.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401121/df_complex-reserved.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401121/df_complex-reserved.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401137/df_complex-reserved.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401137/df_complex-reserved.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401125/df_complex-free.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401125/df_complex-free.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401137/df_complex-free.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401137/df_complex-free.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401146/df_complex-used.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401146/df_complex-used.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step) Jan 9 07:59:26 srv collectd[4558]: rrdtool plugin: rrd_update_r (/var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401121/df_complex-used.rrd) failed: /var/lib/collectd/rrd/srv.placidpools.com.au/df-run-user-1157401121/df_complex-used.rrd: illegal attempt to update using time 1546984684 when last update time is 1546984684 (minimum one second step)
I believe there is nothing to fix. The running backup takes a long time. Let it finisch and set incrimental…
Hello LayLow,
Incremental is set and full backup is scheduled every Saturday only.
Error has been like that every day during Christmas break.
Thanks
This is the issue
Please have also a look at the backup logs:
/var/log/backup-config.log
/var/log/backup-data.log
/var/log/backup/backup-backup-data-(newestDate).log
Fix for the issue was to kill all backup-data-dup processes by issuing:
ps -A | grep dup
Then go to /var/lib/nethserver/backup/duplicity/backup-data/ and delete the lockfile.
We were backing up to NAS via CIFS, but we also sometimes get an error on messages file such as “CIFS VFS: Server has not responded in 120 seconds. Reconnecting…”, hence the reason why the backup would not finish even though it’s only incremental, so we had to change the Nethserver backup to NFS.
