Collabora CODE 21.11
NethServer Version: 7.9.2009 (final)
Module: Nextcloud
Collabora From @mrmarkuz
Updated Collabora CODE from the official repository Collabora News
Problems:
  1. Changed the name of the loolwsd service to coolwsd (need to recreate the service via config set coolwsd …)
  2. coolwsd does not start out of the box. Requires certificates and private key (config in /etc/coolwsd)
    3.changed the URL …/loleflet to …/browser and …/lool to …/cool (can be cured by editing /etc/httpd/conf.d/zz_collabora.conf according to the sample kindly put in /etc/httpd/conf/coolwsd.conf)
Regards
Thanks for raising the issue, I added it and a PR on github to update the packages.
Something went wrong and I can’t assign a reviewer and there’s no nethforge-testing build…but the code should work.
How can I upload files to nethforge? The new version rpms are needed.
an issues is waiting testers, thank you so much @mrmarkuz
