Hi all,
we’ve just completed the new VPN UI for cockpit that links both IPSec and OpenVPN configuration under the same module.
Overview
This module contains 6 menu items:
Dashboard
Contains statistics about your vpn tunnels, both IPsec and OpenVPN (also for roadwarrior).
IPSec
You can create
, update
or delete
IPSec tunnels and also enable
or disable
each tunnels.
OpenVPN tunnels
You can create
, update
, delete
, enable
or disable
both server and client tunnels. For server tunnels you can also download
the configuration.
OpenVPN roadwarriors
You can enable or disable your roadwarrior server and configure it. You can create
, update
, delete
, enable
, disable
, and disconnect
roadwarrior user.
You can also download
or send_with_email
the configuration of roadwarrior account:
Logs and About
Contains the standard views to check logs and get info about the module.
Main news
Roadwarrior
- send OpenVPN configuration using mail
- automatic creation of host object on IP reservation
passtos
option is enabled by default
IPSec / OpenVPN tunnels
- statistics
Breaking changes
Roadwarrior
- push custom routes (not editable from the old Server Manager)
- protocol change UDP/TCP (not compatible with the old Server Manager)
- enable/disable accounts (not compatible with the old Server Manager)
- algorithm and compression selection (not editable from the old Server Manager)
