First Server I setup here locally using my IP range (192.168.25.0) , then I moved it to another location and change the IP range (192.168.16.0). All seems to be working fine, have DHCP and DNS on the Nethserver. However, I find it hard to join clients to the new domain, both Windows 7 and Windows 10.
Once the client has it’s IP say for 15 - 20 min then it joins OK. Is it a bad idea to change IP range like this? I find that if I disable IPV6 on the client it works/joins the NethServer domain easier?
I think the problem is due to DNS. Launch ifconfig /flushdns from cmd and then check if the first dns it’s the IP of DC. Then retry login.
# Windows
ipconfig /flushdns
# Linux
ifconfig /flushdns
Yes, sorry for mistake
Many thanks for your reply, I will test this on my next server.
