look at domain accounts panel.
@flatspin that password was declined. I guess it is only a hash, I am not sureā¦
Correction, that password worked however the user DN should be cn=libuser,dc=directory,dc=nh
Using LDAP Admin, should I set it to anonymous correction I can load the schema and browse the LDAP directory.
Should I select cn=libuser,dc=directory,dc=nh and use the password , testing connection works however when trying to connect I get LDAP error: No such Object!
What I am doing wrong ?
Hello,
Iām very interested in this feature.
Can we have this on NS7?
At least with OpenLDAP (I think is very hard with Samba AD) and at least different domains (NOT ALIAS DOMAIN).
In this moment I use this kind of configuration on NS 6.8, with SOGo.
First of all, I donāt know if it works on NS7. There are a lot of changes.
TIA,
Gabriel
Sorry, I donāt know how to achieve this on NS6/7 , we do it on our XStreamOS based cloud.
Maybe @giacomo or @alefattorini can answer on this specifically for NS.
Webtop itself is prepared to work in a multitenant environment.
Gabriele
Thank you Gabriele for your answer!
NS is designed and built only for once company, but you can use multiple mail domains.
SSSD does support multi-domain authentication, but we have no plan to integrate it.
Iām not sure abot this any more ![]()
We shall investigateā¦
I know that.
With NS 6.8 I use such configuration (a dedicated email server for multiple and different domains).
I donāt know if is possible with NS 7.
I will try to test with WebTop and OpenLDAP, but not in the next days.
For now I try to setup NS 7 RC1 as DC/AD.
Thank you both (you and @davidep), for your responses!
