@iglqut Hi Thomas,
Once you said you have joined the domain with a suse client. Can you help @pike?
Still testing, this How-to of @fausp worked for me on debian 9 xfce
Sure:
Install Suse ( https://de.opensuse.org/Portal:42.3 1 to download ) I use the Gnome version.
After Install search for domain windows in the Dash- there will be an oppertunity to connect to a WIndows Domain- Put in your credentials, then there will be installation of further software, please accept; I think after a restart using at login other User you should be able to log in to your domain using "yourdomain\user
see also: https://freecastleit.wordpress.com/2016/12/21/howto-join-an-opensuse-leap-42-2-client-to-an-existing-windows-activedirectory-ussing-sssd-authentication/ 1
What we also did for having all the data on the server: Mounting the home directory directly at the users home on NS- which is absolutly great- all files and settings are directly stored at the Server and also therefore backuped with the normal backup prozedure- only the network connection must be garanteed. Done on every cllent makes roaming unnecessary. See also Roaming profiles in ns7 Active Directory
We had trouble using our Java based medical documentation software on Gnome so we changed/ additionally installed the KDE Desktop.
Hope that works.
I’m running 4 OpenSuse right now, mostly for test, but one on my laptop;
But you could also make a edgy CentOS by using the last kernel with elrepo;
than making snapshot with snapper by using https://copr.fedorainfracloud.org/coprs/andybe/Centos7Btrfs/packages/
As I mention in another post; the most advantage of OpenSUSE is to be a Rolling Version, than after that snapper.
I also have a VM running Nethserver on btrfs with the last kernel and snapper;
Let’s say; for now everything works fine.
Hi JOduMonT, do you mean the hypervisor or the NS runs on btrfs?
I guess the hypervisor, which one do you use?
The KVM hypervisor is a OpenSUSE Tumbleweed which use brtfs
The VM is based on CentOS/Nethserver which also run on brtfs
oh! in case you ask
simply install CentOS as usual but choose btrfs as filesystem
then initiate snapper
- install the repo
- install the soft + the plugin for yum :
yum install -y snapper yum-plugin-snapper - create the config for your root
snapper -c root create-config /
enjoy and use at your own risk
and also
ref
Oh, vy nice! I have to investigate this solution…
Tried it but without luck, did you do something else?
[admin@ap002 ~]$ groups
domain users domain admins denied rodc password replication group wheel
[admin@ap002 ~]$ sudo su
[sudo] Passwort für admin:
admin ist nicht in der sudoers-Datei. Dieser Vorfall wird gemeldet.
I was able to get sudo rights with the edit of /etc/sudoers:
%domain\ admins ALL=(ALL) NOPASSWD: ALL
But of course this is not the same as the wheel-group method…
No, no extra steps. Did it on fedora, let me spin up a centos vm and report my findings.
OK, thank you, there is no hurry…
Can confirm it does not work on Centos out of the box.
Deducted it to differences centos <> fedora in configuration of nsswitch.
It worked as expected after boldly taking fedora’s nsswitch.conf :
EDIT: removed nsswitch.conf
Did not find smoking gun witch settings made it possible, just adding the missing sudoers: files to the centos default nsswitch.conf did not do the trick. hence the bold move, which no one should do!, to take the complete configuration over.
Grzt Mark
EDIT: found “the smoking gun”
OK Mark, thank you for confirming this issue…
Found why the “ad wheel group” works on fedora and not on centos, on centos in /etc/nsswitch.conf:
missing entry sudoers: files
order of service- calls for group matters: first call the sss and second files Service
# diff -aur /etc/nsswitch.conf.org /etc/nsswitch.conf
--- /etc/nsswitch.conf.org 2018-07-28 17:28:22.250547556 +0200
+++ /etc/nsswitch.conf 2018-07-28 18:10:23.657985095 +0200
@@ -32,7 +32,8 @@
passwd: files sss
shadow: files sss
-group: files sss
+group: sss files
+sudoers: files
#initgroups: files sss
#hosts: db files nisplus nis dns
Very good, I will try it in the next days… Thank you
