Feedback from here so far:
# uname -srm
Linux 5.4.88-v7l.1.el7 armv7l
# scl enable rh-php73 bash
# php --version
PHP 7.3.20 (cli) (built: Jan 27 2021 16:04:42) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.20, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.3.20, Copyright (c) 1999-2018, by Zend Technologies
# exit
# php --version
PHP 5.4.16 (cli) (built: Apr 1 2020 06:27:24)
Copyright (c) 1997-2013 The PHP Group
Zend Engine v2.4.0, Copyright (c) 1998-2013 Zend Technologies
So rh-php73 is present…
# systemctl status rh-php73-php-fpm.service
● .service - The PHP FastCGI Process Manager
Loaded: loaded (/usr/lib/systemd/system/rh-php73-php-fpm.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/rh-php73-php-fpm.service.d
└─nethserver-rh-php73-php-fpm.conf
Active: active (running) since Wed 2021-01-27 18:21:16 UTC; 58min ago
Main PID: 4932 (php-fpm)
Status: "Processes active: 0, idle: 5, Requests: 0, slow: 0, Traffic: 0req/sec"
CGroup: /system.slice/rh-php73-php-fpm.service
├─4932 php-fpm: master process (/opt/rh/rh-php73/root/etc/php-fpm.conf)
├─4933 php-fpm: pool www
├─4934 php-fpm: pool www
├─4935 php-fpm: pool www
├─4936 php-fpm: pool www
└─4937 php-fpm: pool www
Jan 27 18:21:16 rpi4.havak.nl systemd[1]: Starting The PHP FastCGI Process Manager...
Jan 27 18:21:16 rpi4.havak.nl systemd[1]: Started The PHP FastCGI Process Manager.
rh-php73-php-fpm is running…
EDIT: nextcloud log: (yes is it a long line…)
vate/AppConfig.php","line":110,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppConfig.php","line":301,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/legacy/OC_App.php","line":949,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":668,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":155,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"/usr/share/nextcloud/lib/private/ServerContainer.php","line":156,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Memcache\\Factory",true]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1677,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1017,"function":"getMemCacheFactory","class":"OC\\Server","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":155,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OCP\\Lock\\ILockingProvider"]},{"file":"/usr/share/nextcloud/lib/private/ServerContainer.php","line":156,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCP\\Lock\\ILockingProvider",true]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1977,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCP\\Lock\\ILockingProvider"]},{"file":"/usr/share/nextcloud/lib/private/Files/View.php","line":118,"function":"getLockingProvider","class":"OC\\Server","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":395,"function":"__construct","class":"OC\\Files\\View","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":155,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Files\\Node\\HookConnector"]},{"file":"/usr/share/nextcloud/lib/private/ServerContainer.php","line":156,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Files\\Node\\HookConnector",true]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1324,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Files\\Node\\HookConnector"]},{"file":"/usr/share/nextcloud/lib/base.php","line":595,"function":"boot","class":"OC\\Server","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/base.php","line":1091,"function":"init","class":"OC","type":"::","args":[]},{"file":"/usr/share/nextcloud/cron.php","line":42,"args":["/usr/share/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php","Line":42,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist","Code":"42S02","Trace":[{"file":"/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":911,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDOConnection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/usr/share/nextcloud/lib/private/DB/Connection.php","line":202,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":206,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[]]},{"file":"/usr/share/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppConfig.php","line":345,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppConfig.php","line":110,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppConfig.php","line":301,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/legacy/OC_App.php","line":949,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":668,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":155,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"/usr/share/nextcloud/lib/private/ServerContainer.php","line":156,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Memcache\\Factory",true]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1677,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1017,"function":"getMemCacheFactory","class":"OC\\Server","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":155,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OCP\\Lock\\ILockingProvider"]},{"file":"/usr/share/nextcloud/lib/private/ServerContainer.php","line":156,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCP\\Lock\\ILockingProvider",true]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1977,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCP\\Lock\\ILockingProvider"]},{"file":"/usr/share/nextcloud/lib/private/Files/View.php","line":118,"function":"getLockingProvider","class":"OC\\Server","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":395,"function":"__construct","class":"OC\\Files\\View","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":155,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Files\\Node\\HookConnector"]},{"file":"/usr/share/nextcloud/lib/private/ServerContainer.php","line":156,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Files\\Node\\HookConnector",true]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1324,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Files\\Node\\HookConnector"]},{"file":"/usr/share/nextcloud/lib/base.php","line":595,"function":"boot","class":"OC\\Server","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/base.php","line":1091,"function":"init","class":"OC","type":"::","args":[]},{"file":"/usr/share/nextcloud/cron.php","line":42,"args":["/usr/share/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php","Line":83,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist","Code":"42S02","Trace":[{"file":"/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php","line":78,"function":"query","class":"PDO","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":911,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDOConnection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/usr/share/nextcloud/lib/private/DB/Connection.php","line":202,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":206,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[]]},{"file":"/usr/share/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppConfig.php","line":345,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppConfig.php","line":110,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppConfig.php","line":301,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/legacy/OC_App.php","line":949,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":668,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":155,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"/usr/share/nextcloud/lib/private/ServerContainer.php","line":156,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Memcache\\Factory",true]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1677,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1017,"function":"getMemCacheFactory","class":"OC\\Server","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":155,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OCP\\Lock\\ILockingProvider"]},{"file":"/usr/share/nextcloud/lib/private/ServerContainer.php","line":156,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCP\\Lock\\ILockingProvider",true]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1977,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCP\\Lock\\ILockingProvider"]},{"file":"/usr/share/nextcloud/lib/private/Files/View.php","line":118,"function":"getLockingProvider","class":"OC\\Server","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":395,"function":"__construct","class":"OC\\Files\\View","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":155,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":122,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Files\\Node\\HookConnector"]},{"file":"/usr/share/nextcloud/lib/private/ServerContainer.php","line":156,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Files\\Node\\HookConnector",true]},{"file":"/usr/share/nextcloud/lib/private/Server.php","line":1324,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Files\\Node\\HookConnector"]},{"file":"/usr/share/nextcloud/lib/base.php","line":595,"function":"boot","class":"OC\\Server","type":"->","args":[]},{"file":"/usr/share/nextcloud/lib/base.php","line":1091,"function":"init","class":"OC","type":"::","args":[]},{"file":"/usr/share/nextcloud/cron.php","line":42,"args":["/usr/share/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php","Line":78}},"CustomMessage":"--"},"userAgent":"--","version":"20.0.5.2"}
