Just tried but it did not work, strange yesterday uploaded restic just fine.
Maybe better it failed;
Just realized there are a few noarch package among the packages,
Not sure if that is oke…?
I can remove them, please send me a list!
all files:
httpd24-1.1-19.ns7.armv7hl.rpm
httpd24-build-1.1-19.ns7.armv7hl.rpm
httpd24-httpd-2.4.34-22.ns7.armv7hl.rpm
httpd24-httpd-debuginfo-2.4.34-22.ns7.armv7hl.rpm
httpd24-httpd-devel-2.4.34-22.ns7.armv7hl.rpm
httpd24-httpd-manual-2.4.34-22.ns7.noarch.rpm
httpd24-httpd-tools-2.4.34-22.ns7.armv7hl.rpm
httpd24-libnghttp2-1.7.1-8.ns7.1.armv7hl.rpm
httpd24-libnghttp2-devel-1.7.1-8.ns7.1.armv7hl.rpm
httpd24-mod_ldap-2.4.34-22.ns7.armv7hl.rpm
httpd24-mod_proxy_html-2.4.34-22.ns7.armv7hl.rpm
httpd24-mod_session-2.4.34-22.ns7.armv7hl.rpm
httpd24-mod_ssl-2.4.34-22.ns7.armv7hl.rpm
httpd24-nghttp2-1.7.1-8.ns7.1.armv7hl.rpm
httpd24-nghttp2-debuginfo-1.7.1-8.ns7.1.armv7hl.rpm
httpd24-runtime-1.1-19.ns7.armv7hl.rpm
httpd24-scldevel-1.1-19.ns7.armv7hl.rpm
noarch:
Hi Mark, sorry for this late reply: I can’t find those RPMs under http://packages.nethserver.org/nethserver/7.9.2009/
Can you give me a link to understand where they come from?
As said the upload failed for some reason.
http://vps01.havak.nl/nethserver/7/devel/armhfp/Packages/rh-php73/
and the build requirement if you want to be able to rebuild against the (arm) repository:
http://vps01.havak.nl/nethserver/7/devel/armhfp/Packages/httpd24/
I copied those files to
http://packages.nethserver.org/nethserver/7.9.2009/updates/armhfp/Packages/httpd24/
http://packages.nethserver.org/nethserver/7.9.2009/updates/armhfp/Packages/rh-php73/
Could you confirm the upload is successful?
To some extent…
I forgot to tell my development rpm’s are not signed …
And even if they where; guess this would not work in for the NS repo…
EDIT: Successfully installed nethserver-nextcloud with gpgcheck disabled ![]()
…And I forgot to check the signature manually ![]()
Should be fixed now!
confirmed.
Every NS point release a milestone: now we have nextcloud on arm ![]()
For those who want to play with nextcloud on their arm machine.
No need to configure a repository, simply run :
yum install nethserver-nextcloud
