okay here I’m again with my documentation to setup a nethserver 7 based router with raspi3:
- Install CentOs7 on Raspi follow the Nethserver Howto:
http://wiki.nethserver.org/doku.php?id=ns_raspi2
ON FIRST BOOT CHANGE ROOT PASSWORD!!!
- Install MC --> I’m not a fan of vi vim
yum install mc
- change CPU frequency to 1000 Mhz - for faster compiling
mcedit /boot/config.txt
systemctl reboot
- Install Nethserver
yum -y update
yum clean all
new nsswitch.conf is created as nsswitch.conf.rpmnew
cp /etc/nsswitch.conf.rpmnew /etc/nsswitch.conf
yum localinstall http://mirror.framassa.org/nethserver-arm/nethserver-release-7arm.rpm
nethserver-install
- Install Development Tools
yum groupinstall "Development Tools"
yum install nethserver-devtools
- Enable wifi as decribed in /root/README
curl --location https://github.com/RPi-Distro/firmware-nonfree/raw/master/brcm80211/brcm/brcmfmac43430-sdio.bin > /usr/lib/firmware/brcm/brcmfmac43430-sdio.bin
curl --location https://github.com/RPi-Distro/firmware-nonfree/raw/master/brcm80211/brcm/brcmfmac43430-sdio.txt > /usr/lib/firmware/brcm/brcmfmac43430-sdio.txt
systemctl reboot
- Install Hostapd:
yum install libnl3-devel
yum install openssl-devel
download hostapd-src from epl
wget -c http://dl.fedoraproject.org/pub/epel/7/SRPMS/h/hostapd-2.4-3.el7.src.rpm
rpmbuild --rebuild hostapd-2.4-3.el7.src.rpm
yum install /root/rpmbuild/RPMS/armv7hl/hostapd-2.4-3.el7.centos.armv7hl.rpm
edit /etc/hostapd/hostapd.conf
########################################################################################################### begin hostapd.conf
# This will give you a minimal, insecure wireless network.
# DO NOT BE SATISFIED WITH THAT!!!
# A complete, well commented example configuration file is
# available here:
# /usr/share/doc/hostapd/hostapd.conf
# For more information, look here:
# http://wireless.kernel.org/en/users/Documentation/hostapd
ctrl_interface=/var/run/hostapd
ctrl_interface_group=wheel
# Some usable default settings...
macaddr_acl=0 # macaddr_acl will be managed from dhcp ...
auth_algs=1
ignore_broadcast_ssid=0
# Uncomment these for base WPA & WPA2 support with a pre-shared key
wpa=3
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
# DO NOT FORGET TO SET A WPA PASSPHRASE!!
wpa_passphrase=YOURSECRETPASSWORD
# Most modern wireless drivers in the kernel need driver=nl80211
driver=nl80211
# Customize these for your local configuration...
interface=wlan0
hw_mode=g
channel=1
ssid=YOURSSID
########################################################################################################## end hostapd.conf
enable hotapd.service:
systemctl enable hostapd.service
systemctl start hostapd
now you should see your wifi but you wont get an IP address because dhcp is not ready yet
- Build Nethserver-WebContentfilter stuff
download src rpms:
wget -c http://mirrorlist.nethserver.org/nethserver/7.3.1611/base/Source/SPackages/nethserver-squid-1.5.0-1.ns7.src.rpm
wget -c http://mirrorlist.nethserver.org/nethserver/7.3.1611/base/Source/SPackages/nethserver-squidguard-1.6.0-1.ns7.src.rpm
wget -c https://www.urlfilterdb.com/files/downloads/ufdbGuard-1.32.4.src.rpm
nethserver-squid:
rpmbuild --rebuild nethserver-squid-1.5.0-1.ns7.src.rpm
yum install /root/rpmbuild/RPMS/noarch/nethserver-squid-1.5.0-1.el7.centos.noarch.rpm
ufdbguard:
yum install bzip2-devel
create user ufdb - without htis user the RPM will not be packed - why???
useradd -r ufdb -d /var/ufdbguard -M -s /sbin/nologin
rpmbuild --rebuild ufdbGuard-1.32.4.src.rpm
yum install /root/rpmbuild/RPMS/armv7hl/ufdbGuard-1.32.4-CentOS7.armv7hl.rpm
nethserver-squidguard:
rpmbuild --rebuild nethserver-squidguard-1.6.0-1.ns7.src.rpm
yum install /root/rpmbuild/RPMS/noarch/nethserver-squidguard-1.6.0-1.el7.centos.noarch.rpm
9.login to nethserver web surface
set wlan0 to green network
set eth0 to red network
configure dhcp for wlan0
configure web-proxy
configure web-contenfilter
