Okay I checked the urfdbguard reference manual but it’s not so easy to find a start point for debugging. Some hints would be helpful…
At the moment I’m using squid manually with debug level 5 and debugging for ufdbguard is not clear. So I’m not able to check if there are data in blacklist database etc…
okay the path problem seems to be a general problem for arm …
But maybe the config template for ufdbguard ist for a wrong version?
I’m using urfdbguard 1.32.4 and the nethserver-squidguard is working with which version of urfbguard???
Technically a problem with 32 bit architecture, on 64 bit arm (aarch64) this problem does not exist. Although I normally advise against it you could make a simlink /usr/lib64/ > /usr/lib/ for testing.
In the x86_64 nethserver repository is urfdbguard 1.32.4
Can not help you with questions regarding urfdbguard/SquidgGuard
Right. The conversion is done every night after the updated lists are downloaded.
All logs are in /var/ufdbguard/logs/.
In my logs I find:
2016-12-07 15:27:10 [9783] loading URL category defaulttable with creation date 20161207.0420
2016-12-07 15:27:10 [9783] loading URL table from “/var/squidGuard/blacklists/gamble/domains”
2016-12-07 15:27:10 [9783] loading URL table from “/var/squidGuard/blacklists/science/chemistry/domains”
And:
2016-12-05 15:54:35 [7471] received TERM signal
2016-12-05 15:54:35 [7471] statistics: TERM
2016-12-05 15:54:35 [7471] statistics: 287 URL lookups (252 https). 115 URLs blocked. 0 tunnels detected. 0 safe searches. 0 Youtube
edufilter. 172 uncategorised URLs. 3 clients. 1 users.
2016-12-05 15:54:35 [7471] statistics: category gamble was matched 0 times and blocked 0 times
when I open a site which is listed in my custom category blocking is working well and when I open a site which is listed in /var/log/squidGuard/blacklists/adult/domains (flat list) blocking is not working.
I recreated the the database with
ufdbConvertDB /var/squidGuard/blacklists
after deleting the database file.
I checked the file permissions, the owners …
So I’ve no idea what is going wrong. Maybe someone else can test it on arm device too and can share the the results…
during the meantime I contacted Markus from ufdbguard project. He told me that maybe there could be a bug when the ufdb database is created from the flat text list. Maybe it is depending from arm architecture…
I sent him my files for checking. When I’ll get some feedback from Markus I’ll update this post.
here are some informations about the actual state:
Hi Denis,
I looked at the database that you sent and it has a severe corruption
that I cannot explain, but I am sure that it occurs only on the
ARM platform.
Since I do not have an ARM development system it is difficult
to find the root cause of the issue.
I like you to perform a test: go to …/src and
make t1 t2 t3
which produces 3 URL table files:
domains1.in.ufdb domains2.in.ufdb domains3.in.ufdb
and send me the 3 files.
Thanks,
Marcus
So it seems there are some problems under arm arch …
Markus told me that I’m free to send a copy to the nethserver project for testing and he gave a short timeline for the next urfdbGuard release:
Hi Denis,
We plan to implement the last piece of missing IPv6 support into 1.32.5 and that will take a while.
I expect that in two months or so we will release it.
You are free to send of copy of the software that you received to the people of the nethserver project.
Best regards,
Marcus
@filippo_carletti: I’ll share it to the nethserver project with plesure. Please tell me an upload location.
Since ufdbguard is licensed under GPLv2 I think you could upload it to github (or ask Markus if he is willing to do that).
Or you could send it to me as a private message, but I will have to upload it to github to build it.
Or you can send me a pastebin (or similar) link.
Anyway, thank you for your great work with this.
I’ll make sure we have an arm build asap.
Although I do use an RPI, arm acrhitecture is completely new and I honestly know less than little about it. I just want to give a HUGE shoutout to @denis.robel for his work on the webfilter module for arm architecture.
