Hi all
I have run into a truly baffling issue, we run a nethserver openvpn basic roadwarrior setup, all was working swimmingly until just recently i am having trouble connecting to anything on the network like the vpn server for example or our crm system.
we use open vpn client with the standard vpn config file with only the remote ip adjusted.
now when i run the client on my laptop right click connect i log in icon goes green and all looks connected fine but i keep getting really intermittent issues continuous pings run but i can’t connect to the device then pings drop then i can connect to the web interfaces.
i have at least 2 other users who are working fine without problems but have now started to get other people experience the same.
as a sanity check and here is where is gets really weird, i built a new server and put it on an isolated network, so that is new server, new router, new switch, new user new config file,
and guess what same issue, has something changed for road warrior set up?
my ip range is 192.168.30.x/23 subnet 255.255.254.0
client config:
######### NethServer OpenVPN client configuration #########
dev tap
client
remote xxx.xxx.xx.xx
port 1194
float
auth-user-pass
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
comp-lzo
explicit-exit-notify 1
verb 3
persist-key
persist-tun
nobind
