capote
(Marko)
February 15, 2023, 2:32pm
1
I am a member of the board of an association, responsible for communication and membership fee administration.
Do you have a recommendation, with which on Nethserver installable system one could realize member administration?
Important functions:
Contact management
Manage access and exit data
Contribution management (monitoring of the payment)
Newsletter management, with sending depending on the registration for a newsletter
Sincerely, MArko
dan
(Dan)
February 15, 2023, 3:44pm
2
This sounds generally like something that a CRM solution would help with–something like Odoo.
Andy_Wismer
(André Wismer)
February 15, 2023, 3:49pm
3
@capote
You could try Dolibarr, it has Membership for an Association built in, additional modules are also available…
capote
(Marko)
February 15, 2023, 7:30pm
4
Hi Andy, thank you for the reminder.
I installed dolibarr now and…
I set my domain
config setprop dolibarr DomainName mydomain.de
signal-event nethserver-dolibarr-update
…and set access to public
config setprop dolibarr access public
Check:
config show dolibarr
dolibarr=configuration
DomainName=mydomain.de
MaxExecutionTime=0
MaxFileUploads=20
MemoryLimit=128
MysqlAuth=disabled
PostMaxSize=8
UploadMaxFilesize=4
access=public
rpmVersion=16.0.3
status=enabled
I can access via: https://mydomain.de/htdocs/
but not via : https://mydomain.de/dolibarr
Dolibarr is well integrated into my AD. The AD-admin have access with admin permissions.
Sincerely, Marko
mrmarkuz
(Markus Neuberger)
February 15, 2023, 8:40pm
5
You need to remove the DomainName value to make Dolibarr reachable like https://domain.tld/dolibarr.
config setprop dolibarr DomainName ''
With a DomainName, Dolibarr is reachable at https://domain.tld, see also dolibarr [NethServer Wiki]
capote
(Marko)
February 15, 2023, 9:18pm
6
Thank you, I misunderstood
DomainName (not set by default) use a FQDN domain name. Once set, dolibarr is reachable at https://toto.com instead of https://your_ip/dolibarr
It should be
DomainName (not set by default) use a FQDN domain name. Once set, dolibarr is reachable at https://toto.com instead of https://your-domain.tld/dolibarr
capote
(Marko)
February 15, 2023, 9:21pm
7
There is a German SKR49 chart of accounts to be imported into dolibarr.
But can’t find a matching import option. Does anyone have an idea?
mrmarkuz
(Markus Neuberger)
February 15, 2023, 9:41pm
8
After enabling the Data Import module you’ll find an import assistent in the tools page but I had import errors…
capote
(Marko)
February 17, 2023, 8:20am
9
I tried to update the system. I downloaded and expanded the upgrade package to /usr/share/dolibarr/ and unlocked the update script
But the new version is not recognized…
What could be the reason for this behavior?
-rw-r--r-- 1 root root 493669 Jan 5 14:38 ChangeLog
-rw-r--r-- 1 root root 1911 Jan 5 14:38 composer.json.disabled
-rw-r--r-- 1 root root 35151 Jan 5 14:38 COPYING
-rw-r--r-- 1 root root 6953 Jan 5 14:38 COPYRIGHT
-rw-r--r-- 1 root root 1366 Jan 5 14:38 DCO
drwxr-x--- 30 apache apache 4096 Feb 17 00:53 documents
drwx------ 7 root root 240 Feb 17 00:43 dolibarr-16.0.4
-rw-r--r-- 1 root root 80973216 Feb 17 00:41 dolibarr-16.0.4.zip
drwxr-xr-x 78 root root 4096 Feb 15 19:32 htdocs
-rw-r--r-- 1 root root 741 Jan 5 14:38 nightwatch.conf.js
-rw-r--r-- 1 root root 11416 Jan 5 14:38 phpstan.neon
-rw-r--r-- 1 root root 7722 Jan 5 14:38 README-FR.md
-rw-r--r-- 1 root root 10282 Jan 5 14:38 README.md
-rw-r--r-- 1 root root 95 Jan 5 14:38 robots.txt
drwxr-xr-x 2 root root 114 Feb 15 19:32 rpm_logs
drwxr-xr-x 16 root root 224 Feb 15 19:32 scripts
-rw-r--r-- 1 root root 6660 Jan 5 14:38 SECURITY.md
I can’t find any indicator in the log.
Last but not lease I changed the ownership chown apache:apache -R /usr/share/dolibarr/
total 79672
-rw-r--r-- 1 apache apache 493669 Jan 5 14:38 ChangeLog
-rw-r--r-- 1 apache apache 1911 Jan 5 14:38 composer.json.disabled
-rw-r--r-- 1 apache apache 35151 Jan 5 14:38 COPYING
-rw-r--r-- 1 apache apache 6953 Jan 5 14:38 COPYRIGHT
-rw-r--r-- 1 apache apache 1366 Jan 5 14:38 DCO
drwxr-x--- 30 apache apache 4096 Feb 17 09:14 documents
drwx------ 7 apache apache 240 Feb 17 00:43 dolibarr-16.0.4
-rw-r--r-- 1 apache apache 80973216 Feb 17 00:41 dolibarr-16.0.4.zip
drwxr-xr-x 78 apache apache 4096 Feb 15 19:32 htdocs
-rw-r--r-- 1 apache apache 741 Jan 5 14:38 nightwatch.conf.js
-rw-r--r-- 1 apache apache 11416 Jan 5 14:38 phpstan.neon
-rw-r--r-- 1 apache apache 7722 Jan 5 14:38 README-FR.md
-rw-r--r-- 1 apache apache 10282 Jan 5 14:38 README.md
-rw-r--r-- 1 apache apache 95 Jan 5 14:38 robots.txt
drwxr-xr-x 2 apache apache 114 Feb 15 19:32 rpm_logs
drwxr-xr-x 16 apache apache 224 Feb 15 19:32 scripts
-rw-r--r-- 1 apache apache 6660 Jan 5 14:38 SECURITY.md
Now I have no idea anymore.
Andy_Wismer
(André Wismer)
February 17, 2023, 10:42am
10
Hi @capote
AFAIK, you should get Updates when @Stephdl releases them…
I get a mail saying there’s an update for Dolibarr from Stephdl’s repo…
capote
(Marko)
February 17, 2023, 10:52am
11
okay…
But the documentation explains how to update the program manually.
dan
(Dan)
February 17, 2023, 10:58am
12
Here’s what the documentation says, with emphasis added:
The upgrade or the installation should be handled automatically , however if after an upgrade something is wrong, the dolibarr software will ask you to perform manually the upgrade through the web installer.
Where in those instructions do you see “download the upgrade package and expand it over your existing installation”?
capote
(Marko)
February 17, 2023, 11:03am
13
there:
The software tells me, it exists a new update, do following steps.
There is no warning
Never make a manual update.
If the manual update is a dead end, the wiki should say so.
On top of the wiki:
or if you just want to upgrade (the repository is disabled by default)
yum upgrade nethserver-dolibarr dolibarr --enablerepo=stephdl-dolibarr
then do a signal-event nethserver-dolibarr-update
Package(s) dolibarr available, but not installed.
No packages marked for update
It’s confusing for me.
Andy_Wismer
(André Wismer)
February 17, 2023, 12:37pm
14
@capote
Generally, follow whatever instructions are available from where you got the software.
If using the NethServer Module by Stephdl, follow his instructions.
If you installed the software on “some” linux box, you follow the instructions from Dolibarr.
Same is valid especially for Nextcloud, and most other Modules for NethServer…
capote
(Marko)
February 17, 2023, 12:51pm
15
as I have shown, I thought I had done just that
stephdl
(Stéphane de Labrusse)
February 17, 2023, 3:27pm
16
permission on the folder ?
mrmarkuz
(Markus Neuberger)
February 17, 2023, 3:35pm
17
No, I don’t think so. It was an error about the CSV import of the German account plan but maybe I would have needed to change the mapping somehow.
Maybe the account plan is for an older version of Dolibarr…
LayLow
(LayLow)
February 17, 2023, 10:58pm
19
capote:
I asked…
Hopefully the combined wisdom will bring a solution.
Andy_Wismer
(André Wismer)
February 17, 2023, 11:35pm
20
@capote
Just wanted to mention that I did not have problems importing the swiss chart of accounts into Dolibarr…
