A little hint for Realtek NICs users experiencing stability and availability issues
NethServer Version: 7.9
Module: operating system
Backstory…
My first NethServer “test/crash test dummy/sacrifice install” is called Scapegoat not for nothing…
This is the configuration of this shoddy machine.
Riepilogo
lscpu|grep Model
Model name:            Intel(R) Core(TM)2 Duo CPU     E6750  @ 2.66GHz`
dmidecode -t 2
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 2.4 present.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
        Manufacturer: Intel Corporation
        Product Name: DG31PR
        Version: AAD97573-204
        Serial Number: BTPR749001QH
        Asset Tag: To be filled by O.E.M.
        Features:
                Board is a hosting board
                Board is replaceable
    Location In Chassis: To be filled by O.E.M.
    Chassis Handle: 0x0003
    Type: Motherboard
    Contained Object Handles: 0
lspci
00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 02)
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 02)
00:02.0 VGA compatible controller: Intel Corporation 82G33/G31 Express Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 01)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01)
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 01)
(the audience can laugh with full disrespect now)
This old piece of hardware gave quite a big chunk of issues during it’s “linux life” life, mostly “working without working”.
I “solved” issues shutting down and removing hardware: graphic card for saving ram, add-on network cards, some things like that.
Also changed few disks, but the stability issue remained during the life. I were not worried about the distro: mainboard is rather old, even PSU, never though about something different than hardware; nevertheless, stability issue remained.
Until this date…
When I installed the “right” kmod for my network card.
As wrote several times, i’m not an experienced or skilled linux sysadmin, therefore my experience and trickbag for performance tuning and troubleshooting is… poor. But about reliability of my setup, that was quite the gamechanger.
The host never issued any “lacking” of availability anytime called. For updates, tests, rollbacks. Also changing the hard drive, recently called back the package the restore.
Therefore, here are my walktrough for installing the “right” kmod.
  • Checkup your card. The real one:
    lspci |grep Ethernet
  • Verify if there is any available “specific” driver/module/whathever for your network adapter
  • Take the note how to install it, and even how to remove it.
  • Install the driver (my command was yum install kmod-r8168)
  • Put a note on your calendar about when you installed it and … whey you’re gonna draw the line for “something changed”?
I were helped by the recent update of the kmod, therefore i rembered “two months withour any issue”. But… can happen to anyone, no?
There’s only a little “downside”, IMVHO: install of updates.
My kmod don’t ask any effort for being installed, updated, managed, but the time for installing new driver/kmod or kernel increase a lot. Also, a reboot is mandatory not only for a new kernel bugfix, but also for a new version of kmod. I had to stop messing with the fancy yum update -y (which i don’t reccomend to anyone running a production server) and checkup/manual update time-to-time isolating the update of the kernel and/or the kmod addon.
Hoping that helps some Realtek user with… issues. :wink:
So. Where the hell i put that old graphic card?
With this kind of adapter
you can install this kmod as test, maybe can solve your issue.
As someone already did…
https://forums.centos.org/viewtopic.php?t=69134
Oh, i had my share of problems with that NIC back when i used to use ClearOS.
I do remember the kmod solution! thanks for that!
thanks for the awesome information.
I changed my mainboard…
dmidecode |grep Product
        Product Name: DG41RQ
A with a bit better watt-to-computational ratio CPU
cat /proc/cpuinfo  |grep name
model name      : Pentium(R) Dual-Core  CPU      E5400  @ 2.70GHz
But with “kinda the same” NIC
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03)
Almost 200hrs of flawless work. Rebooted today for a newer kernel
uname -r
3.10.0-1160.41.1.el7.x86_64
uptime
 16:56:22 up  5:32,  0 users,  load average: 0.63, 0.43, 0.48
A little update…
I showed into my test server 2 more network cards… The output is…
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
04:01.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8169 PCI Gigabit Ethernet Controller (rev 10)
But only the second one appeared into my Cockpit dashboard. The output of find /sys | grep drivers.*04:01 was… null. After a small yum install kmod-r8169 the output was… slightly different.
/sys/bus/pci/drivers/r8169/0000:04:01.0
And the Cockpit showed both network adaper. A nice Whooo and a small hooo raised.
Take your time for install, frequently modbprobe take… some time.
