Yes I tested myself to set to another TZ manually (Moscou), it just worked
what user did you used ?
root ?
root ?
Yes, user is root.
cat /var/lib/nethserver/2fa/root
please what is the output
[root@sx.x.x.x.server ~]# cat /var/lib/nethserver/2fa/root
cat: /var/lib/nethserver/2fa/root: No such file or directory
ok back to the first mind…I do not know what you are facing…
what browser do you use ?
what OS do you use ?
MS Edge or FireFox
OS on Client is WIN 10 Enterprise. OTP app works on my iPhone.
try chrome, but it works on FF
I do not have a apple, I cannot try, only android
Same situation with chrome. I have a old notebook with linux mint. I will test it with this and report later.
I use it with linux…
No problems with linux mint and firefox.
hum what the hell crosoft has done
Dont ask me… Sometimes i think it’s time to say good bye to ms and windows.
But now it’s time for the coffee.
Thanks for helping.
thanks for testing :), now I know of to reproduce
what version of EDGE, chrome and FF did you tested on windows
does other user of microsoft windows could valid that it fails ?
FF latest Version 74.0
Also Edge latest Version 80.0.361.66
Not tested with Chrome, because i dont like it to have parts of Google software on my clients.
Tested with all my four WIN 10 Enterprise Clients with Edge and FF with the latest Patchlevel.
Result: Not possible to activate 2FA
Last Test with my iPad IOS 13 and Safari.
Result: I can activate 2FA without problems
oathtool --totp 'KEY'
We could use this and get rid of the JS library, we can create a time token and validate it from the user input. This time it is the server itself which provides the token, not the remote browser, theoretically we could have a bad validation if the user input is made in the last second of token life
I made a bug report to the otplib in GH, let’s see if I am the bug
sorry @transocean I cannot reproduce, I tested myself with a W10 and FF74, it simply just works
Scan the QR code with freeotp
fill the input verification field with the number read on freeOTP
press test, the verification if valid allows to save the form (save become blue)
if you want to test on Windows with EDGE, Chrome and firefox @support_team please
yum install http://packages.nethserver.org/nethserver/7.7.1908/autobuild/x86_64/Packages/nethserver-cockpit-1.4.6-1.40.pr191.gfc9fe7a.ns7.noarch.rpm http://packages.nethserver.org/nethserver/7.7.1908/autobuild/x86_64/Packages/nethserver-cockpit-lib-1.4.6-1.40.pr191.gfc9fe7a.ns7.noarch.rpm -y
I also tested with Win10 and Linux, no problem so far.
same problem like last weekend. No way with WIN 10, FF or Edge.
Possible only with Linux and FF or Apple IOS 13 with Safari.
Within the next days i will test it with a fresh WIN 10.
Regards
Uwe
