yum clean all && rm -rf /var/cache/yum && yum -y update
Cleaning repos: base centos-sclo-rh centos-sclo-sclo collaboraoffice.com_repos_CollaboraOnline_CODE-centos7 epel
: extras nethforge nethserver-base nethserver-updates remi-php56 remi-safe updates veeam
Cleaning up everything
Maybe you want: rm -rf /var/cache/yum, to also free up space taken by orphaned data from disabled or removed repos
Cleaning up list of fastest mirrors
Determining fastest mirrors
epel/x86_64/metalink | 13 kB 00:00:00
Could not retrieve mirrorlist http://mirrorlist.nethserver.org/7/nethserver?release=7&repo=nethforge&arch=x86_64 error was
12: Timeout on http://mirrorlist.nethserver.org/7/nethserver?release=7&repo=nethforge&arch=x86_64: (28, ‘Connection timed out after 30001 milliseconds’)
One of the configured repositories failed (Unknown),
and yum doesn’t have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work “fix” this:
1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working
upstream. This is most often useful if you are using a newer
distribution release than is supported by the repository (and the
packages for the previous distribution release still work).
3. Run the command with the repository temporarily disabled
yum --disablerepo=<repoid> ...
4. Disable the repository permanently, so yum won't use it by default. Yum
will then just ignore the repository until you permanently enable it
again or use --enablerepo for temporary usage:
yum-config-manager --disable <repoid>
or
subscription-manager repos --disable=<repoid>
5. Configure the failing repository to be skipped, if it is unavailable.
Note that yum will try to contact the repo. when it runs most commands,
so will have to try and fail each time (and thus. yum will be be much
slower). If it is a very temporary problem though, this is often a nice
compromise:
yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true
Cannot find a valid baseurl for repo: nethforge/7/x86_64
Cleaning repos: base centos-sclo-rh centos-sclo-sclo collaboraoffice.com_repos_CollaboraOnline_CODE-centos7 epel extras
: nethforge nethserver-base nethserver-updates remi-php56 remi-safe updates veeam
One of the configured repositories failed (NethServer-7 - Base),
yum --disablerepo=nethserver-base ...
yum-config-manager --disable nethserver-base
or
subscription-manager repos --disable=nethserver-base
compromise:
yum-config-manager --save --setopt=nethserver-base.skip_if_unavailable=true
Do not prompt, what I need to adjust the mirror?
It’s amazing that the mirrors were working yesterday before the update and suddenly blocked after the update. As we have seen, the IPS does not block the server. Therefore it is not in the lock, then locks himself NethServer.
Look at the .repo files in /etc/yum.repos.d directory. You can comment out the mirrorlist= line and have your own baseurl= line with the mirror site of your choice. You can list multiple sites if you wish.
Добрый всем день!
IP зеркала заблокированы провайдерами интернета в России. Попали под раздачу наверно при блокировки Telegram. Есть другие варианты или иные зеркала для стабильной установки и обновления?
Good day everyone!
IP mirrors are blocked by Internet providers in Russia. Got under the hand, probably at a blocking Telegram. Are there other options or other mirrors for a stable installation and upgrade?
Sorry, but we don’t have another machine running the mirrorlist service.
I suggest you to disable the mirrorlist from the Nethserver.repo configuration file, then enable the baseurl option selecting a mirror from this list http://mirror-status.nethserver.org/
For reference
you can configure the proxy on the server with one command
it works for me
through a proxy updated server
Use the following syntax to configure traffic types such as http, https, and ftp from the command line:
export ftp_proxy=»http://proxy-server:port»
export http_proxy=»http://proxy-server:port»
export https_proxy=»https://proxy-server:port»
