Hi all
I have not been here in some time, I am back with questions as usual. Can an upgrade from NS 6.8 to NS 7 be done on a live running system without crashing it?
Hi Lewis,
Welcome back!
No, you canāt!
There is somewhere in this forum more details for āwhy notā but I canāt find now to show you the path.
You can read more about NS 7, here:
http://docs.nethserver.org/en/v7b/release_notes.html
Gabriel
Thanks Gab.
I think that we will work on the 6 -> 7 live update after we release 7 final.
Let me wait on that for now. Thank you @filippo_carletti
another waiting +1
I cant wait⦠tackle the problems and errors at hand its the best way to learnā¦
Better make that a rock solid procedure. I know āthat other distroā has always been struggling with upgrades to new versions. Avoid problems at all cost!
Hi good people
Just checking if any luck on the upgrade from 6.8 to 7?
We will work on it after the release of NS 7 stable
FTR, which distro?
I guess Something that starts with a āZā
Fo those waiting for an upgrade path⦠itās time to raise your voice and share your thoughts :
Did the upgrade get completed from 6.8 to 7? Can we live upgrade?
Not yet, weāre currently working on it
+1 for live upgrade to NS7
Upstream doesnāt support anymore upgrade from 6 to 7:
https://wiki.centos.org/TipsAndTricks/CentOSUpgradeTool
And⦠whereās that leave us?
weāll give it a try, after the backup-restore procedure is finished!
http://wiki.nethserver.org/doku.php?id=developer:ns7_upgrade#in-place_upgrade
This would be a HUGE ouch if this means that upgrade from NS6x -> NS7.x would mean backup, install from scratch and restoreā¦
