Thanks for reporting issues back to Nextcloud! This is the issue tracker o…f Nextcloud, if you have any support question please check out https://nextcloud.com/support
This is the bug tracker for the Server component. Find other components at https://github.com/nextcloud/
For reporting potential security issues please see https://nextcloud.com/security/
To make it possible for us to help you please fill out below information carefully.
### Steps to reproduce
1. Install NC on shared host (all-inkl with SSL Lets encrypt in my case) using mySQL
2. Create user
3. OS X - Finder - Cmd+K: Connect to https://host.url/remote.php/webdav using user credentials
4. Try to upload a file
### Expected behaviour
File should be uploaded.
### Actual behaviour
File with 0 kB is created, but Finder shows error message (German) "Der Finder konnte diesen Vorgang nicht abschließen, da einige Daten in „coupon2.pdf“ nicht gelesen oder geschrieben werden konnten.
(Fehler: -36)" Error:-36
**Upload with Cyberduck via WebDAV (HTTPS) works.**
### Server configuration
**Operating system**:
Linux 3.13.0-105-generic #152-Ubuntu SMP Fri Dec 2 15:37:11 UTC 2016 x86_64
**Web server:**
Apache
**Database:**
MySQL Server-Version: 5.6.33-nmm1-log - (Ubuntu)
**PHP version:**
7.0.10-NMM1 as CGI/FPM
**Nextcloud version:** (see Nextcloud admin page)
11.0.0
**Updated from an older Nextcloud/ownCloud or fresh install:**
10.0.2 / same behavior for fresh install
**Where did you install Nextcloud from:**
tar file from nextcloud.com
**Signing status:**
<details>
<summary>Signing status</summary>
No errors have been found.
</details>
**List of activated apps:**
<details>
<summary>App list</summary>
Contacts
Calendar
</details>
**The content of config/config.php:**
<details>
<summary>Config report</summary>
<?php
$CONFIG = array (
'instanceid' => '[REMOVED]',
'passwordsalt' => '[REMOVED]',
'secret' => '[REMOVED]',
'trusted_domains' =>
array (
0 => '[REMOVED].[REMOVED].[REMOVED]',
'datadirectory' => '/www/htdocs/[REMOVED]/[REMOVED]_data',
'tempdirectory' => '/www/htdocs/[REMOVED]/[REMOVED]_temp',
'overwrite.cli.url' => 'https://[REMOVED].[REMOVED].it',
'dbtype' => 'mysql',
'version' => '11.0.0.10',
'dbname' => '[REMOVED]',
'dbhost' => 'localhost',
'dbport' => '',
'dbtableprefix' => 'oc_',
'dbuser' => '[REMOVED]',
'dbpassword' => '[REMOVED]',
'logtimezone' => 'UTC',
'installed' => true,
'mail_from_address' => '[REMOVED]',
'mail_smtpmode' => 'php',
'mail_domain' => '[REMOVED].[REMOVED]',
'loglevel' => 0,
'mail_smtpsecure' => 'ssl',
'theme' => '',
'maintenance' => false,
</details>
**Are you using external storage, if yes which one:** No.
**Are you using encryption:** yes, but same behavior without encryption (tested with new installation)
**Are you using an external user-backend, if yes which one:** No.
### Client configuration
**Browser:**
Finder (Browser upload works)
**Operating system:**
Mac OS X 10.12.2
### Logs
#### Nextcloud log (data/nextcloud.log)
<details>
<summary>Nextcloud log</summary>
{"reqId":"[REMOVED]","remoteAddr":"[REMOVED]","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 404 File with name coupon2.pdf could not be located\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\NotFound\",\"Code\":0,\"Trace\":\"#0 \\\/www\\\/htdocs\\\/[REMOVED]\\\/[REMOVED]\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(939): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\ObjectTree->getNodeForPath('coupon2.pdf')\\n#1 \\\/www\\\/htdocs\\\/[REMOVED]\\\/[REMOVED]\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(336): Sabre\\\\DAV\\\\Server->getPropertiesForPath('coupon2.pdf', Array, 0)\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPropFind(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/www\\\/htdocs\\\/[REMOVED]\\\/[REMOVED]\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/www\\\/htdocs\\\/[REMOVED]\\\/[REMOVED]\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:PROPFIND', Array)\\n#5 \\\/www\\\/htdocs\\\/[REMOVED]\\\/[REMOVED]\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/www\\\/htdocs\\\/[REMOVED]\\\/[REMOVED]\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(60): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/www\\\/htdocs\\\/[REMOVED]\\\/[REMOVED]\\\/remote.php(165): require_once('\\\/www\\\/htdocs\\\/w01...')\\n#8 {main}\",\"File\":\"\\\/www\\\/htdocs\\\/[REMOVED]\\\/[REMOVED]\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/ObjectTree.php\",\"Line\":173,\"User\":\"Michael\"}","level":0,"time":"2016-12-29T18:34:33+00:00","method":"PROPFIND","url":"\/remote.php\/webdav\/coupon2.pdf","user":"Michael","version":"11.0.0.10"}
</details>
