NethServer Version: 7.4
Module: nethserver-hotsync
I’ve seen Hotsync doesn’t work, but mine seems to be a different issue–at least, it’s a different error message. Every 15 minutes, I’m getting emails saying this:
hotsync error: rsync returned 12. rsync output:
rsync: read error: Connection reset by peer (104)
rsync error: error in rsync protocol data stream (code 12) at io.c(764) [sender=3.0.9]
Master:
[root@neth ~]# config show hotsync
hotsync=configuration
MasterHost=
SlaveHost=192.168.1.60
SlavePort=273
databases=enabled
role=master
status=enabled
Slave:
[root@neth-backup ~]# config show hotsync
MasterHost=192.168.3.3
SlaveHost=
SlavePort=273
databases=enabled
role=slave
status=enabled
I’ve run signal-event nethserver-hotsync-update on both systems, with no change. Both systems are running
[root@neth ~]# rpm -q nethserver-hotsync
nethserver-hotsync-2.0.1-1.ns7.noarch
Each machine can ping the other. They are connected via VPN, if it matters. Suggestions?
