Tried to use the url of my nethserver and still getting the same issue.
When I try to start the service it will not start. Below is what I show in the error log
Oct 24 21:50:31 sogod [7797]: version 3.2.10 (build mockbuild@e7548133f2f948bfa5761043e51bbb38 201707121401) ā starting
Oct 24 21:50:31 sogod [7797]: vmem size check enabled: shutting down app when vmem > 384 MB. Currently at 311 MB
Oct 24 21:50:31 sogod [7797]: <0x0x5631380a9ce0[SOGoProductLoader]> SOGo products loaded from ā/usr/lib64/GNUstep/SOGoā:
Oct 24 21:50:31 sogod [7797]: <0x0x5631380a9ce0[SOGoProductLoader]> AdministrationUI.SOGo, Appointments.SOGo, CommonUI.SOGo, Contacts.SOGo, ContactsUI.SOGo, MailPartViewers.SOGo, Mailer.SOGo, MailerUI.SOGo, MainUI.SOGo, PreferencesUI.SOGo, SchedulerUI.SOGo
Oct 24 21:50:31 sogod [7797]: All products loaded - current memory usage at 349 MB
Oct 24 21:50:31 sogod [7797]: <0x0x5631381a0e90[WOWatchDog]> listening on 127.0.0.1:20000
Oct 24 21:50:31 sogod [7797]: <0x0x5631381a0e90[WOWatchDog]> watchdog process pid: 7797
Oct 24 21:50:31 sogod [7797]: <0x0x7fe7610a9980[WOWatchDogChild]> watchdog request timeout set to 10 minutes
Oct 24 21:50:31 sogod [7797]: <0x0x5631381a0e90[WOWatchDog]> preparing 3 children
Oct 24 21:50:31 sogod [7797]: <0x0x5631381a0e90[WOWatchDog]> child spawned with pid 7798
Oct 24 21:50:31 sogod [7797]: <0x0x5631381a0e90[WOWatchDog]> child spawned with pid 7799
Oct 24 21:50:31 sogod [7797]: <0x0x5631381a0e90[WOWatchDog]> child spawned with pid 7800
Oct 24 21:50:31 sogod [7798]: [ERROR] |SOGo| No value specified for 'SOGoProfileURLā
Oct 24 21:50:31 sogod [7798]: <0x0x5631382e4b20[WOHttpAdaptor]> notified the watchdog that we are ready
Oct 24 21:50:31 sogod [7799]: [ERROR] |SOGo| No value specified for 'SOGoProfileURLā
Oct 24 21:50:31 sogod [7799]: <0x0x5631382e4b20[WOHttpAdaptor]> notified the watchdog that we are ready
Oct 24 21:50:31 sogod [7800]: [ERROR] |SOGo| No value specified for 'SOGoProfileURLā
Oct 24 21:50:31 sogod [7800]: <0x0x5631382e4b20[WOHttpAdaptor]> notified the watchdog that we are ready
Oct 24 21:51:40 sogod [7797]: <0x0x5631381a0e90[WOWatchDog]> Terminating with SIGINT or SIGTERM
Oct 24 21:51:40 sogod [7797]: <0x0x56313817aee0[WOWatchDogChild]> sending terminate signal to pid 7800
Oct 24 21:51:40 sogod [7797]: <0x0x56313817a4e0[WOWatchDogChild]> sending terminate signal to pid 7799
Oct 24 21:51:40 sogod [7797]: <0x0x56313817a120[WOWatchDogChild]> sending terminate signal to pid 7798
Oct 24 21:51:40 sogod [7797]: <0x0x56313817a120[WOWatchDogChild]> child 7798 exited
Oct 24 21:51:40 sogod [7797]: <0x0x56313817a4e0[WOWatchDogChild]> child 7799 exited
Oct 24 21:51:40 sogod [7797]: <0x0x56313817aee0[WOWatchDogChild]> child 7800 exited
Oct 24 21:51:40 sogod [7797]: <0x0x5631381a0e90[WOWatchDog]> all children exited. We now terminate.
systemctl -l status sogod
ā sogod.service - SOGo is a groupware server
Loaded: loaded (/usr/lib/systemd/system/sogod.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2017-10-24 18:06:08 EDT; 2h 14min ago
Oct 24 18:06:07 tlh.schines.net systemd[1]: Starting SOGo is a groupware serverā¦
Oct 24 18:06:08 tlh.schines.net systemd[1]: sogod.service: control process exited, code=exited status=1
Oct 24 18:06:08 tlh.schines.net systemd[1]: Failed to start SOGo is a groupware server.
Oct 24 18:06:08 tlh.schines.net systemd[1]: Unit sogod.service entered failed state.
Oct 24 18:06:08 tlh.schines.net systemd[1]: sogod.service failed.
