Hello community
We are moving from NethServer 7 to NethSecurity. On the NethServer instance there is a LAN and Guest network setup. The VM’s on the Guest network can’t access the LAN but VM’s on the LAN can access VM’s on the Guest network. For the life of me I can’t get this setup on the NethSecurity.
If I follow the Guest setup in the documentation VM’s in the LAN zone can’t access VM’s in the Guest zone. I have also tried various “allow forwards from” and “allow forwards to” combinations but as soon as I don’t have then both enabled in both zones all communication between zones stops. Any idea what I’m doing wrong or is the desired setup not possible?
