I’m trying to install Zammad on Nethserver 7. Not sure if it still runs under NS7, but I would like to try it. If not, I’ll have to rush my migration from NS7 to NS8.
I installed nethserver-zammad using mrmarkuz repo and followed instructions.
I suppose that after install I would open the url I set up and proceed with installation: database, etc etc.
All I get is an error 500
class=“error-message”<% end %>>
500: We’re sorry, but something went wrong.
<% if !@traceback %>
Fom /var/log/zammad/production.log I can only see: can’t connect to DATABASE (does not exist). Makes sense, setup is not done.
elasticsearch is running:
● elasticsearch.service - Elasticsearch
Loaded: loaded (/usr/lib/systemd/system/elasticsearch.service; enabled; vendor preset: disabled)
Active: active (running) since Seg 2025-10-06 11:15:16 WEST; 6h ago
Docs: https://www.elastic.co
Main PID: 9331 (java)
Tasks: 57
Memory: 4.0G
CGroup: /system.slice/elasticsearch.service
├─9331 /usr/share/elasticsearch/jdk/bin/java -Xshare:auto -Des.networkaddress.cache.ttl=60 -Des.networkaddress.cache.negative.ttl=10 -XX:+AlwaysPreTouch -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -XX:-OmitStackTraceInFastThrow -XX:+ShowCodeD…
└─9578 /usr/share/elasticsearch/modules/x-pack-ml/platform/linux-x86_64/bin/controller
Out 06 11:14:53 systemd[1]: Starting Elasticsearch…
Out 06 11:15:16 systemd[1]: Started Elasticsearch.
I couldn’t reproduce, here it works but it takes some time until it’s started after the configuration.
Did you install Zammad 5 on the NS7? It’s documented in the wiki.
Zammad for NS8 is currently broken, I need to update it.
I removed my previous installation, followed zammad5 instructions and now it works like a charm.
Well, it is installed. Now it’s the second stage: explore the solution.
its mainly broken due to the use of ElasticSearch container from our guys at bitnami, Due to bitnami, policy change, currently sourcing a suitable docker image, with not breaking changes, that can be replaced, to be useable.
I’m sure it will be another fantastic contribution. In the meanwhile, I’m happy with zammad working on NS7 for testing and exploring before deploying it on NS8 nodes,
